Thread: Connection hub
17-05-2020 #1
I'm still labouring away on updating my Fehlmann P50CNC, This is quite a complex machine and I have a lot of control and power supply (5v and 24v) wires that need to be distubuted.
I need a hub to bring together the wiring into a convenient place in the cabinet. I really just need something that can be screwed down to the base plate (or mounted to a din rail) with some high quality screw terminals so I can bring wires in and then take them out to relay boards (the sort with 2.54mm pitch pins).
Searching through eBay I can only find breakout boards with output sockets which are of no use. If it comes to it I'mm make something, but I'm sure there must be something ready made out there - I'm just searching for the wrong thing.
Thanks, David
17-05-2020 #2
Here you go these sort of things will do the job.
https://www.ebay.co.uk/itm/Dual-Row-...FIR6mnOJHnbFiQ
https://www.ebay.co.uk/itm/600V-15A-....c100005.m1851-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
17-05-2020 #3
Thanks Jazz, but I have plenty of that sort of thing - far too brutal. What I need is something with these nice little screw terminals - https://ebay.us/MV6BaJ
The application is for control volatages of 5v and 24v at very low current. There seem to be plenty of Arduino related boards or boards with d-sub connectors but none that are just straight through.
17-05-2020 #4
17-05-2020 #5
17-05-2020 #6
I've sometimes found that I've spent more time on the web looking for a neat off-the-shelf solution than it would have taken me to make something myself - doh!
18-05-2020 #7
18-05-2020 #8
I was thinking along these lines:
https://www.amazon.co.uk/Her-Kindnes...CREEVH1Q82NRAZ
https://www.amazon.co.uk/Dinkle-Asse.../dp/B01KMW7MY2
18-05-2020 #9
Aye up!!
Hows this....
https://www.amazon.co.uk/Electronics.../dp/B07BHJ7LCG
18-05-2020 #10
Which Connection ?
By manofgresley in forum Stepper & Servo MotorsReplies: 17Last Post: 13-07-2020, 01:55 PM -
UC400ETH connection to PC/Laptop
By Palletlad in forum General ComputingReplies: 1Last Post: 24-05-2019, 03:05 AM -
z axis probe connection
By thewww in forum Motor Drivers & ControllersReplies: 3Last Post: 30-11-2018, 08:18 PM -
Or Guidance ;) Connection Name(s)
By Carlb1058 in forum Marketplace DiscussionReplies: 6Last Post: 13-07-2013, 12:48 AM -
Wire Connection Diagrams
By Lee Roberts in forum Stepper & Servo MotorsReplies: 14Last Post: 03-01-2013, 06:56 PM
