    I think this should be a simple 3d shape to cut - a simple flat triangle with a 72deg chamfer on 2 edges - the idea is to cut 5 which will then be stuck together to make a pentagon pyramid.
    the whole thing is quite small (25 mm from base to point) and I'm using a 1mm flat bit - I went for a 3d contour and it generates to toolpaths except for 2 very annoying things.
    I selected 3d contour and used the top and bottom contours to cut to
    the cut doesn't go all the way down to the bottom contour
    It won't cut along the vertical (short side) -I've tried using other modes with the same result
    I'm clearly setting something wrong in using contour (I've only used it in 2d mode before) - can anyone help me with what I'm dong wrong ??
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Share your file, happy to have a look at it later...
    In the meantime - is your tool long enough? Maybe increase the additional offset for the machining boundary...
    Chances are you'll sort it on your own after a bit of button mashing - F360's a bit like that..!
    Wal.
    Cheers Wal - I can't seem to be able to attach the file itself- saying invalid format - I'd be very happy to email it.
    I just tried it with changing the bit parameters to 1mm by 70mm long - didn't make any difference :-(
    Wal's Avatar
    Try zipping it..?
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Britannicus View Post
    just add .txt to the end of the file name
  1. Fusion 360 question
    By Britannicus1 in forum General Discussion
    Last Post: 31-01-2020, 02:33 PM
  2. Fusion 360
    By Clive S in forum General Discussion
    Last Post: 17-10-2019, 08:19 AM
  3. Fusion and Mach3
    By dfox1787 in forum Fusion 360
    Last Post: 06-03-2018, 07:21 PM
  4. fusion 360 cnc parts
    By charlieuk in forum Fusion 360
    Last Post: 24-05-2017, 02:23 PM
  5. Fusion Problems
    By cropwell in forum Fusion 360
    Last Post: 04-03-2017, 07:39 PM
