21-05-2020 #2
Hi Ian,
You're missing a key bit of information - how are the screws retained axially?
Typically people use a fixed block at one end (often the driven end) and a floating block at the other. These are often of the FK/FF or BK/BF variety.
You might be able to feel the screw moving backwards and forwards as you pull on it with 0.15mm of backlash, if so that would imply you need to look at the screw rather than the ball nut.
Cutter accuracy
By Neale in forum Tool & Tooling TechnologyReplies: 21Last Post: 02-09-2017, 03:23 PM -
Cut depths and spindal speeds to improve finsh time
By Fivetide in forum Tool & Tooling TechnologyReplies: 23Last Post: 21-05-2015, 08:39 AM -
Improve Kress TIR or get an upgrade?
By Hauk in forum Kress Milling MotorsReplies: 3Last Post: 23-02-2014, 06:18 PM -
trying to improve my board game
By cubikoman in forum General DiscussionReplies: 28Last Post: 12-05-2012, 06:57 AM -
NEW MEMBER: cubikoman needs to improve quality of his boardgame
By cubikoman in forum New Member IntroductionsReplies: 2Last Post: 16-02-2011, 12:17 PM
