Thread: PSU size calculation
Hi
these ones from steppersonline:
https://www.omc-stepperonline.com/cl...nd-driver.html
19-05-2020 #2
Ok well then the limiting factor now is the 50vdc Max drive limit. For safety you really need to leave a 10% safety margin for back Emf when the mootrs are slowing down and effectively turn into dynamos and send voltage back to the drives etc.
So 45Vdc is the Max you can run these motors at safely. If you try to push more then you risk the chance of blowing the drives up.
What machine is this going on.?-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
How-To: Feed Rate Calculation
By Lee Roberts in forum Machine DiscussionReplies: 20Last Post: 25-03-2020, 04:09 PM -
How Strict is the Max Vsupply Calculation for Steppers?
By mattnedgus in forum Motor Drivers & ControllersReplies: 14Last Post: 02-08-2019, 08:55 AM -
O-ring calculation
By Clive S in forum General DiscussionReplies: 3Last Post: 18-03-2017, 04:54 PM -
pulse equivelant calculation
By yasser in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 17-05-2016, 10:10 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
