starting to put my base together from 50x100 Misumi milled face profile, Y axis is 1100mm,
can anyone give me feed back on the pro's and cons of either mounting the rails on top of the profile or mounting on the sides (cheeks)
on top makes alignment between rails a little easier but not that side mount is impossible.
on top will raise my gantry by a bit,
what is the preferred method ?
Dave
22-05-2020 #2
On top would be my choice, it's much easier and allows a stronger gantry.! . . . . However, must say these sort of decisions should have been made a long time before you started building the base. If you are taking the design as you build it route then expect a lot of wasted material and design changes.
You'll save your self a lot of grief and money if you sit down and design all the major areas of the machine first.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
23-05-2020 #3have most of the design pretty much fixed, however what looks good in CAD does not always translate to the real world, Many things will change as the build takes shape, as i discover the disconnect between Screen and reality.However, must say these sort of decisions should have been made a long time before you started building the base. If you are taking the design as you build it route then expect a lot of wasted material and design changes.
Y rail position is a fairly easy change at this point.
I have worked on cheek mounted rails as thats how things evolved in CAD but as i start to construct that little devil on my shoulder keeps questioning my decisions.
Bolts for Linear Rail?
By Tenson in forum General DiscussionReplies: 4Last Post: 02-03-2018, 02:08 PM -
Couple of questions about carriage positioning on X axis and z axis rails
By Richard in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 19-11-2017, 10:16 AM -
Looking for a cost effective place to buy HGR35 linear rail and blocks, any advice.
By marbles in forum Marketplace DiscussionReplies: 2Last Post: 01-10-2017, 10:51 AM -
Linear rail advice
By Darren in forum Rails, Guideways & BearingsReplies: 0Last Post: 09-04-2016, 11:15 PM -
Needing advice on linear rail blocks
By oldmam4m80s in forum Rails, Guideways & BearingsReplies: 0Last Post: 27-10-2013, 07:57 AM
