24-05-2020 #8
Unless you are using a 4th or 5th axis then you can't machine 3D in one sitting. Best you can do is 2.5D without turning the work over to finish a true 3D object.
Even if you use Fusion to create a true 3D model the G-code it's spitting out will only be 2.5D code when using 3-axis and aspire will do everything fusion will in that respect.
Your only selecting the surfaces on a 3D model which can be accessed by a 3 axis interpolation, if you want to access undercuts etc of a true 3D model then you will need to re-fixture or add another axis or two.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
G30 programming
By Leadhead in forum Programmers CornerReplies: 3Last Post: 04-06-2017, 09:13 AM -
NEW MEMBER: Hello all, New member here from London, keen woodworker and interest in homebuild
By justice86 in forum New Member IntroductionsReplies: 0Last Post: 06-11-2013, 01:02 AM -
I will have a trial for programming job
By hoezap in forum Tool & Tooling TechnologyReplies: 7Last Post: 09-02-2013, 03:00 PM -
Programming an engraver
By patch in forum Computer SoftwareReplies: 2Last Post: 24-11-2009, 10:11 PM -
Programming Mach3 screens
By Smiler in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 17-01-2009, 03:15 AM
