    If your going to go with Closed loop then your better going with 3 phase closed loop. The step angle is 1.2deg instead of 1.8deg so much smoother and the extra phase gives them a bit more torque higher up the speed curve. Only down side is they only come with 50Vdc Max drives unless you go upto Nema 34.
    I've fitted loads of these and this company is good to deal with.
    https://www.aliexpress.com/item/3303...61cf761f3tsKRK
    RE Vat then it's dependant on the amount declared on the customs paper work (and there in lies a clue to getting it down) usualy there is no import duty other than a rip off fee of around £15- £20 the shipping agent charges for paper work.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Thanks Dean,
    They probably the best performance to cost ratio currently ? As still have the ballscrews to purchase so trying to get good performance as like everyone I have a budget
    This will be paired with UCCNC and a u300eth (bought already) - If I get these I may need help wiring hehe
    also would the 50Vdc make a massive difference compared to a 2 phase with 70-80Vdc driver
    thanks again
    Quote Originally Posted by Hulksmash View Post
    Yes it will mostly make a difference to the speed but not by a massive amount, roughly 300rpm, these will give 1200rpm and the others will be 1500rpm.
    They are not exactly like a standard stepper system and the encoders come into play so can restrict the speeds.
    If I wanted to have excess power and plenty of speed along with AC drives then I'd fit these and sacrifice the smoothness 3phase offers as they are 2 phase.
    Nothing gets close to these for power in the Nema 24 range. Again I've fitted plenty.
    https://www.aliexpress.com/item/3279...16523421DXQOr7
    The wiring is easy enough just shout if you need help.
    Not fair!!!!!
    Just looked at buying 2 and it wants £90 shipping?????
    Quote Originally Posted by dazp1976 View Post
    Not fair!!!!!
    email them.
    Jazz. I was wondering if you could clear something up for me. I was looking at these motors and drives you recommended and on the pics it says 20-70v ac. Is that correct or is it 220 ac straight input.
    Quote Originally Posted by johngoodrich View Post
    Yes John it's 20-70Vac or 30-100Vdc. The AC option Just saves messing around with Bridge and Caps but still need a transformer to get from 230Vac to 20-70Vac.
    Some of the Larger Nema 34's drives like these work direct from 230Vac mains. These are great for larger machines because they spin fast and have loads of torque.
    https://www.aliexpress.com/item/3279...3cac6f37mUvHpT
  1. CONVERSION: Weiss VM32 Mill Conversion
    By picclock in forum Conversion Build Logs
    Last Post: 07-08-2019, 11:27 PM
  2. CONVERSION: Warco WM18 Mill Stepper motor advice
    By Gotty101 in forum Conversion Build Logs
    Last Post: 18-08-2018, 05:06 PM
  3. Stepper motor selection, lower inductance vs holding torque
    By smeg up in forum Stepper & Servo Motors
    Last Post: 20-01-2015, 02:43 AM
  4. Weiss WMD25LV mill
    By Bill K in forum Milling Machines, Builds & Conversions
    Last Post: 29-06-2014, 12:52 PM
  5. EXPERIENCE: corkcnc ... a short tale
    By purpose in forum Trading Experience & Feedback
    Last Post: 29-12-2013, 04:43 PM
