I havn't bought anything the reason i asked was that 8mm seemed a bit small for a large machine. i can twist steel with a impact wrench of that thickness.
ok so it looks like its back to making the rack and pinion design.
need to find a engineering company locally to cut the side plates and swing arms. (once i have the design finalised)
hopefully you can make out the idea for the pressure adjust on the rack and pinion. it is early stages but closer than most.
the more i look into it, the more complex it is. not impossible though
