Page 1 of 9 123 ... LastLast
  1. Good Day All.
    Has anyone here got or do you know anything about the TB6560 stepper motor driver boards that are being sold on eBay.
    From the bad english in the ebay listings it looks like thease boards can run upto 36volts and upto 3amp stepper motors.
    But detailed info is very limited.
    I am just after your toughts on this item.
    Thanks for your time.
    Best Regards.
  2. Quote Originally Posted by Mad Professor View Post
    Good Day All.
    Best Regards.
    First thing to understanmd is never believe what suppliers say the capabilities of their boards are... read the datasheet for the chips and look at the construction.
    Here we have 4 TB6560 devices sharing a single force cooled heatsink approx 30mm x 80mm x 10mm. That heatsink has a thermal resistance of about 6decC/watt and with the fan thats maybe improved to 4degC/watt (the airflow is pretty restricted). So each device is effectively fixed to a heatsink of 16degC/Watt (under worst case conditions - all axis functioning) or 12degC/W for 3-axis use.
    Now look at the datasheet for the TB6560. Its allowed to run the junction at 150degC max before the thermal shutdown cuts in and the thermal resistance junction to case is 1.5degC/W. So adding that to the heatsink you have (3-axis) 12.5degC/W thermal resistance. So maximum dissipation at 25degC ambient is (150 - 25)/10.5 = 10W.
    The power dissipation of the chip is approx 2 x On resistance x output current^2 = 2 x 0.4 x I^2 and this is maximum 10W so rearranging
    I = sqrt(10/(2 x 0.4)) = sqrt(10/0.8) = 3.5A
    So on the face of this this board can run 3A/phase steppers at full output on 3-Axis, and will probably be ok on 4-axis, but its pushing close to the thermal cutoff of the chip...
  3. The Following User Says Thank You to irving2008 For This Useful Post:
  4. I like this bit.
    Suppliers Warranty:
    We offer one month warranty on all products purchased from us. If your item has any warranty issue please contact us for a satisfying solution.
    Is that from delivery or dispatch?
  5. I have ordered one of thease TB6560 boards back on the 27/10/2009, before I asked about them here.
    I have no idea how long it is going to take to get from china to me with all the dam royal mail strikes on going.
    The eBay ad says that it should only take upto 6-10 business days, but I will have to wait and see.
    I went for the TB6560 over the TA8435H as it is ment to support upto 36volts, and the TA8435H can only support upto 24volts.
    I am going to be using this board with my Astrosyn MY103H702 stepper motors.
    I am looking at running 34volts to try and get as much speed out of the stepper motors as possible.
    I will report back once I have got the board.
  6. #5
    Hi
    I'm interseted to see how you get on, I've been looking at them myself but put off by the fact its all on one board and max 36v.
    But £50 ish for 4 axis with opto sounds like my budget
  7. Well the post and been and gone today, but no sign of my parcel yet.
    Oh well it looks like I will not get unto next week now.
    I have been reading the so called bad english manual for the driver board to work out what DIP Switch settings I am going to need.
    I am only intrested in switches 1-4.
    Switches 1-2 are for the current setting, 100%, 75%, 50%, 25%.
    Is this a case of 3.00amps, 2.25amps, 1.50amps, 0.70amps, or does the board self sence the current and when at idle or hold, hold the current at said % of the stepper motors max current.
    Next is Switchts 3-4 for the Buffer, the manual just has, Fast, 25%, 50%, Slow, so at a guess I need to set it to Fast.
    Then the last two switches 5-6 are for the step modes, this I understand.
  8. It was ordered on the 27/10/2009, and posted on the 28/10/2009, and got here today 10/11/2009, so two weeks to the day from ordering.
  9. #8
    Hows it going with that board then Mad professor? any joy with it yet?
    I've now got exactly the same board and motors sitting on my table, i'm just waiting for my pci parallel port extension to turn up so i'm dying to find out how much money wasted/saved
  10. Dan Brown: I have not done any more testing since after removing the damaged chip.
    I have tested that all the other axis are still working using my adjustable bench power supply, but I can only run the board / motors upto 15volts on this power supply.
    But at this lower voltage my current rig is very slow, max of 200mm/min, for the very short time that the board was running at 36vdc I was closer to 450mm/min rapid move, not cutting.
    I will be back to testing the current sence resistor and dip switches.
    When using my scope with my bench PSU I always have to use my laptop on battery, as if the laptop on mains or a PC is used I get very strange readings on the scope software, so thats something else I have to look into.
  11. Quote Originally Posted by Mad Professor View Post
    As per my thread above, on 36v the max step rate for these motors is 900steps/sec, thats 270rpm or about 500mm/min on a 2mm pitch screw.
    Sounds like you have some ground loop problems. Make sure stepper PSU and scope/PC are on same power socket so they are earth referenced together. I cant use the same PC as the scope and the driver for the stepper, for the same reason...
  1. Replies: 1
  2. 4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
    By TommeyReed in forum Motor Drivers & Controllers
    Last Post: 06-03-2012, 06:01 PM
  3. FOR SALE: 4 Axis TB6560 Stepper Motor Driver Board
    By Mad Professor in forum Items For Sale
    Last Post: 04-01-2011, 06:54 PM
  4. eBay TB6560 Stepper Motor Driver Boards
    By irving2008 in forum Motor Drivers & Controllers
    Last Post: 07-04-2010, 04:48 PM
  5. manual for eBay TB6560 Stepper Motor Driver Boards?
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 06-01-2010, 10:37 PM
