Page 5 of 9 FirstFirst ... 34567 ... LastLast
    I came across this site a while ago and just found it again which makes for n interesting build
    http://www.cnc-hotwire.de/
  2. Re: CNC-gesteuerte Heißdrahtschneidemaschine
    I had looked at that hanging hotwire system before. Looks awsome for a basic limitted space occassional home use.
    I downloaded the English version. May have to have a play with it down the track. For now I will concentrate on the basics of Mach3/Profili2 standard hotwire CNC machine.
    If anyone has some experience with the English version, love some insight into your experience with it.
    Hi all,
    I recently got this TB6560 board from eBay as well. Are there any schematics of this board available?
    Greetings,
    Hermann
  4. Over the last few weeks I have had a number of people contact me via PM's asking me questions regarding the TB6560 boards.
    One that keeps being asked is the lack of performance (speed) when using microstepping.
    I have so far been unable to answer this one.
    I had some free time today, so I decided to test my board with microstepping, and guess what I have the same lack of performance (speed).
    I scoped the input step signal from the computer, and the step signal to the TB6560 chip.
    The step pulses (0-5KHz) from the pc can be seen without a problem.
    But there is something strange with the step pulses from the opti to the TB6560.
    I was expecting to see a 0-5v square wave, or at least something close to it.
    But it's more a 0-5v pulse then ramps back to ground.
    The faster the step pulse the more the ground moves away, and at around 4.8KHz the ground is so high that the TB6560 can no longer see the step pulses.
    http://www.mad-professor.co.uk/Misc/...0@%20300Hz.jpg
    http://www.mad-professor.co.uk/Misc/...@%204.1KHz.jpg
    http://www.mad-professor.co.uk/Misc/...20@%205KHz.jpg
    Blue scope trace is the input to the board, and the red scope trace is the step input at the TB6560 Chip.
    Following the traces on the PCB this is what I have come up with for the Schematic.
    Looking at the datasheet for the TB6560 says that it is good for upto 15Khz.
    "If first you don't succeed, redefine success"
    Theo's Avatar
    Lives in Assen, Netherlands. Last Activity: 21-10-2010 Has been a member for 9-10 years. Has a total post count of 4.
    This link was posted in a other forum. Maybe its a solution??
    Use Google translate
    Andy
    It sounds a bit worrying that the fan is not working and would suggest that is sorted first as these boards require sufficient cooling. The LED's to blink and be on is common as some of the pins are live on the port (note do not plug in or out the cable when switched on). I have the older version of this type of board and it does the same thing whilst booting the PC. How many axis does your board support?
    Hello,
    - so input voltage of 24 V is ok ?
    - should the fan start o turn in the moment the board is connected to power supply ?
    - i have 3 axis board...
    Thanks for any input...
    Regards
    Andy
    Yes the fan should start up straight away so check the 12v supply and wires to the fan. The recommendation of many is to not go beyond 24v so that is fine. Can you supply the details of your steppers and how you have them wired as this will help in diagnosis. List the connections you have made and any config settings in Mach3 would help also. I am afraid i use EMC2 so can not run through the config of Mach3 with you but i am sure somebody else here can validate that for you
    Hello,
    ok, thanks Y/Z Axis working. X not working. I figured out that i have permanent -0.22V out of PIN 1 (X-step). While for Y and Z i have 0 V and -0,02V when axis is moved. So does anybody knows why i have these -0.22V permanent output ? The DIR PIN for X axis is working - so only the PIN 1 is the problem. I checked in mach, an no other functions are related to PIN 1.
    Thanks for any input - step by step t will work someday..
    Regards from Germany
    Andy
    Quote Originally Posted by masterploxis View Post
    Hello,
    Andy
    Did you get your X working as I have the same problem? also anyone notice the pin outs on the board for the steppers are different to the instruction sheet which is right?
  1. Replies: 1
  2. 4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
    By TommeyReed in forum Motor Drivers & Controllers
    Last Post: 06-03-2012, 06:01 PM
  3. FOR SALE: 4 Axis TB6560 Stepper Motor Driver Board
    By Mad Professor in forum Items For Sale
    Last Post: 04-01-2011, 06:54 PM
  4. eBay TB6560 Stepper Motor Driver Boards
    By irving2008 in forum Motor Drivers & Controllers
    Last Post: 07-04-2010, 04:48 PM
  5. manual for eBay TB6560 Stepper Motor Driver Boards?
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 06-01-2010, 10:37 PM
