28-10-2010 #11
Hello,
after i did not get response from cnczone i´ll try my first port here:
first problem first post:
I got the board from ebay (seller prettyworthshop)....
I connected the board to power supply with was included. The boards gets 24V - i measured that with a meter.
I connected the board to computer (LPT is set to ECP). I set all the MACH 3 parameters according to the manual (Signal in, Signal out, Motor....)
On the board itself we have 3 LEDS for which show when signal is available for axis movment. If i press cursor in MACH the middle LED (Y) glows only a bit. Above the 3 LEDS there are two LEDS and the right one is on all the time when i connect the parallel cable with the board. When is disconnect, the LED goes out.
The fan is not turning. Motor is connected but not moving...
I don´t know whats the problem. Can somebody help me ?
I hope to get this first problem soved with your help.
By the way - i built the MDF CNC Machine from buidyourcncDOTcom. I want to use tha machine for milling panels for my DIY 737-800 Homecockpit...
Cheers from Wuerzburg Germany
Andy
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM -
FOR SALE: 4 Axis TB6560 Stepper Motor Driver Board
By Mad Professor in forum Items For SaleReplies: 1Last Post: 04-01-2011, 06:54 PM -
eBay TB6560 Stepper Motor Driver Boards
By irving2008 in forum Motor Drivers & ControllersReplies: 13Last Post: 07-04-2010, 04:48 PM -
manual for eBay TB6560 Stepper Motor Driver Boards?
By Dan Brown in forum Motor Drivers & ControllersReplies: 5Last Post: 06-01-2010, 10:37 PM
