Same motors I have.
I was wondering if the switches are actually adjusting the idle current when the motor is stationary and not the operating current, the data sheet isnt clear. If that was the case then the 100% setting corresponds to the RMS phase current set by the resistors which would be the RMS current shown by the ammeter
The maximum peak current this could be for these motors on 13.3v (allowing .5v for Vref) is:
Unipolar: 13.3/6.2 = 2A (which appears to be your bipolar series setting)
Bipolar Parallel 13.3/3.1 = 4A
Bipolar Series 13.3/12.4 = 1A (which appears to be your bipolar parallel setting)
Do you have a stand-alone ammeter or a 'scope?
10-11-2009 #2
I have tested the voltage outputs from both phases, and they are both powered wile at idle.
Bipolar Parallel: 4.00 to 4.15volts.
Bipolar Series: 12.95 to 13.00volts.
I do have a DVM with ammeter but it is quite old so don't know how good it will be.
I also do have a PicoScope 2202 USB Oscilloscope.Last edited by Mad Professor; 10-11-2009 at 07:27 PM.
10-11-2009 #3
10-11-2009 #4
I am running PicoScope v6.3.4.0.
I have not had this scope long so I am still finding my way around the settings, so I am not 100% sure what you are after.
Bipolar Parallel:
True RMS Avg 120mv.
Peak to Peak Avg 1.15v
Bipolar Series:
True RMS Avg 80mv.
Peak to Peak Avg 30mv.
10-11-2009 #5
11-11-2009 #6
Sure I can save the waveforms, do you want them as screenshots or save the waveforms to an output file?
11-11-2009 #7
I usually do screen capture or print as PDF.
Attached are 3 captures from my L297/L298 board using the same motor at 500, 750 and 900 steps/sec on a 36v supply, wired bipolar parallel (coil resistance = 3.2ohm).
This shows the A-enable signal (blue) and the sense voltage (red). The sense voltage is directly proportional to the current in the coil (x 2), so .5v = 1A. At 500stesp/sec the RMS voltage is 0.64v, a current of 1.3A RMS, the peak voltage being 0.9v equivalent to 1.8A. You can see that the current doesn't start to flow (indeed its negative slightly at the start of the cycle which is due to the back emf/collapsing field of the previous cycle) until 0.7mS into the cycle, it then ramps up due to the inductance of the coils (these being high inductance motors i.e. not very fast) until it finally gets to the current limit and the driver goes into chopping.
At 750stesp/sec the RMS current has dropped to about 1A, the peak still being 1.8A. This is because the initial start-up and ramp is a greater proportion of the cycle time.
At 900steps/sec the current never gets to the set limit before the cycle ends... this is the fastest the motor will go at this voltage and the power output wil be low, the RMS current here is about 0.5A.
To go faster with these motors needs about 70v...
Setting Vref using the scope like this is much more accurate than adjusting it statically or relying on the overall current consumption.
22-03-2012 #8
i know this is an old post, but ive just come accross it. ive been on cnczone and asked about a full kit for my first build.
i have been told.
Run far and fast from that controller. Search this site for TB6560 and you'll have all the info you need. Almost 500 posts in this threadalone.
so what do you think...
hope to get much info on ere. im in the uk myself.
:confused:
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM -
FOR SALE: 4 Axis TB6560 Stepper Motor Driver Board
By Mad Professor in forum Items For SaleReplies: 1Last Post: 04-01-2011, 06:54 PM -
eBay TB6560 Stepper Motor Driver Boards
By irving2008 in forum Motor Drivers & ControllersReplies: 13Last Post: 07-04-2010, 04:48 PM -
manual for eBay TB6560 Stepper Motor Driver Boards?
By Dan Brown in forum Motor Drivers & ControllersReplies: 5Last Post: 06-01-2010, 10:37 PM
