Thread: Fuling DZB200 Inverter
Okay, so F0.03 is defaulted to '0'?, so that's keyboard input. What happens if you Press RUN then press the UP (/DOWN) buttons - that *should* change the speed setting and the motor RPM. Report back.
You *could* (later) change F0.03 to 1, I would expect (guess) that would then allow the rotary pot to control the spindle speed.
EDIT:
Until you can get the VFD to indicate a speed other than 0, then trying to diagnose the spindle behaviour is a bit of guesswork
How to connect 2.2KW Inverter VFD?
By Tenson in forum Spindles & Drive MotorsReplies: 20Last Post: 13-07-2020, 01:47 PM -
Just blown up my inverter
By Lodds in forum Generic Chinese SpindlesReplies: 32Last Post: 01-01-2018, 06:49 PM -
2.2KW 3HP Inverter help
By adamh in forum Spindles & Drive MotorsReplies: 8Last Post: 31-07-2015, 09:21 AM -
WANTED: Electrical Box for inverter
By badgerman in forum Items WantedReplies: 1Last Post: 28-09-2013, 11:08 PM -
Teco inverter
By Ronaldo9 in forum Spindles & Drive MotorsReplies: 9Last Post: 20-01-2013, 01:42 PM
