    Could some one please recommend a fairly accurate mechanical edge finer that I can buy in UK? I have used the cheap ones which I bought from Aliexpress, but they are not accurate enough it seems.
    Also, I like to get some recommendations for 100mm (or similar) sized vise. I have used one of these but it lifts the work piece when tightened.
    https://www.cromwell.co.uk/shop/hand...s-vices/f/3250
    Would these ones be any better as they have a 45 degree angle in the tightening screw?
    https://www.amazon.co.uk/VS-SLV2A-To.../dp/B003042IPS
    Please note that this is for hobby/home use so very expensive equipment will not work for me.
    Quote Originally Posted by suspension View Post
    And therein lies your problem.!! . . . . you get what you pay for. Quality cost's money and I've found it's better to just lube up and take the pain because it's cheaper and less frustrating long term.
    Try Cutwell tools for quality vise's, cheap vises are just expensive future paperweights.!!
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 21 Hours Ago Has been a member for 8-9 years. Has a total post count of 476. Received thanks 77 times, giving thanks to others 25 times.
    You might have noticed that no self-respecting Youtube Workshop Warrior in the US feels able to approach a machine tool that isn't equipped with the obligatory Kurt vise - or two would be even better. However, the real benefit of the Kurt vise and its myriad copies is the "angle lock" feature that pulls the jaws down as they are clamped. The tighter you make it, the more the jaws are pulled down. There are loads of indifferent copies out there and I bought one of those Chinesium versions a few years back. The angle lock part itself turned out to be barely functional, as the tolerances were so far out. I ended up remachining that bit but of course that's basically ladling lipstick on a pig.
    If you can get a half decent angle lock type vise without having to cough up the full price of a new Kurt (best part of a grand), you can find a workable half way house. I got a 6" version from Arc Euro Trade last year and it's been fairly well made. Ketan's done a decent job of quality controlling his Chinese supplier there.
    https://www.arceurotrade.co.uk/Catal...-Milling-Vices They also do a 4" version I see - and the price isn't bad. Shipping a POS lump of scrap cast iron from AliExpress over to the UK is an expensive business, which doesn't leave much for the "vise" itself..
    I used the 100mm Arc Euro Trade Vice on a small mill and it was very good for the price.
    As for edge finder, I bought one of these when doing my apprenticeship twenty years, I still have it and is is accurate, although it has been mostly replaced with a haimer probe.
    https://www.cromwell.co.uk/shop/hand...s-sets/f/64760
    Muzzer's Avatar
    I prefer this sort of edge finder, although I must admit I've not tried the "wobbler" sort jamesgates1000 mentions. I'm starting to sound like a shill for Arc Euro but Cromwell don't seem to sell them and this came to hand. https://www.arceurotrade.co.uk/Catal...l-Edge-Finders
    Forget where I got mine but it's 10mm shank and 4mmm tip, looking like their "Type C".
    Have to admit I didn't know how to use it until I found one of these dummy guides on YT. Then it started to make sense and I realised how sensitive some of these tools can be.
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    Any non angle lock vice will nearly always cause stock to lift, as the moving jaw will lift up when tightening.
    If it's a high enough bit of stock, put a bit round bar between the moving jaw and the work piece, snug it up, then give the material a tap down with a hammer (ideally made from something softer than the material you're hitting, unless you're not worried about leaving marks) to make sure the materials seated against the base.
    But as per Jazz's post, I love my Gerardi vice from Cutwel, but they're probably a touch expensive (even when on offer!) for hobby use.
    I am refering to this:
    https://m.aliexpress.com/item/330612...d=7573amp-xll8
    Could you please provide me a link to a video or tutorial which has instructions on how to use this properly? In my case amount of movement required to make the tip move to side is from centered position is fairly high.
    Deleted
    covered by other post
    been looking for a precision vice too, i started a thread on it and soon will be making a decision.
    Im torn between these 2, not sure if they are helpful to you -
    https://saundersmachineworks.com/pro...ise-system-1-2
    https://www.zoro.co.uk/shop/hand-too...m/p/ZT1011146X
    CNC: OMIO X4 800L
    HG15+20 Linear Guide Rails
    1605 Ball screws
    0.8kW Air-cooled spindle
    Muzzer's Avatar
    AS you may be aware, the Saunders vise requires several sets of Mitee Bite Talon thingies as well as the Saunders fixture plate to mount it on - or your own equivalent. The adjustment range is almost zero, as you fix the vise up against the work, then nip up the Talons. That's good for repetitive work but a PITA for the more normal stuff I do and the cost would fairly add up by the time you have a workable system.
    I like the look of those Zoro / Geradi etc vises. I'd like to acquire one some day when I can find an excuse....
  1. Any ideas or thoughts on making a edge finder come touch off tool
    By suesi34e in forum Electronic Project Building
    Last Post: 01-01-2020, 06:28 AM
  2. Mach3 Edge Finder
    By dfox1787 in forum Artsoft Mach (3 & 4)
    Last Post: 08-03-2018, 10:27 AM
  3. Where to buy from sound and led 1/2" shank or ER25 edge finder, ?
    By Boyan Silyavski in forum Tool & Tooling Technology
    Last Post: 28-04-2016, 12:01 AM
  4. 1/4" / 6mm edge finder?
    By jcb121 in forum Marketplace Discussion
    Last Post: 18-03-2013, 02:58 PM
  5. Electronic edge finder: how do they work?
    By irving2008 in forum Probing, Digitizing & Scaning
    Last Post: 29-08-2009, 10:25 PM
