Page 2 of 2 FirstFirst 12
    screenshot attached guys, 500mb is the max file size...
    ...note the maximum width and/or height for images though: 2048 x 1536 pixels.
    "Insert Inline" adds images to a post in the way your looking for...bottom right of the popup window.
  2. The Following User Says Thank You to Lee Roberts For This Useful Post:
  3. #12
    Am presuming you meant 500kB there Lee.
    On that basis I will try to cleam up my thread
  4. #13
    No no 500mb :)
    I think I have got there AT LAST.
    I had to resize my pics to less that 500kB
    Then select the "insert image "icon in the header which gives you a popup which you can then select and upload your image
    Then go to "manage uploads" (only available if I "go advanced")
    That gives a further window in which you can select and tick your required pic , drag it into the uploads part of the window
    and only then you can "insert inline "
  6. #15
    Lives in East Lothian, United Kingdom. Last Activity: 7 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,971. Received thanks 369 times, giving thanks to others 9 times.
    It's more likely the width and height limitation that you fell foul to.
    Easiest way for resizing if you're using Windows, is to use Paint. It's resize option lets you select either percentage or pixels.
  7. #16
    I use paint to resize , and with pics under 500kB I have managed to include in thread so I think it was more to do with procedure than size .
    A Sticky topic explaining how to do it would help.
    Not exactly intuitive in this forum software ICW othere forums I visit
  8. #17
    I am still struggling with this .
    Pics seem to disappear from text for no reason then reappear in the attachment block . This can make nonsense of the text.
    Can someone write (in words of one syllable) a procedure for including a pic in the text.
    I have to say that I have no difficulty with this on other sites but the attachment manager here makes hard work in comparison with other platforms
  9. #18
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 14 Hours Ago Has a total post count of 301. Received thanks 28 times, giving thanks to others 13 times.
    John,
    My way of doing it:
    First write your text what you want to say.
    to insert image press enter twice to start new line. look for icon Insert image above press "Chose file" from computer find the folder you have the image in select it, then click on Upload file (files) Click image for larger version.
ID:	28422 it will place it wherever your cursor is. or you can move it down
ID:	28422 by placing your cursor lower like this.
    hope it helps
    Phill
  1. Replies: 1
    Last Post: 23-02-2020, 11:44 PM
  2. Replies: 1
    Last Post: 22-07-2016, 02:15 PM
  3. Funny machining pics
    By oscar in forum Workshop & Equipment
    Last Post: 30-05-2013, 03:55 PM
  4. BUILD LOG: small mill for machining steel. Max spend £500 including computer
    By Andrew Wilding in forum DIY Mill Build Logs
    Last Post: 20-07-2012, 03:46 PM
  5. BUILD LOG: Few pics of my homemade CNC mill
    By wiatroda in forum DIY Router Build Logs
    Last Post: 18-02-2011, 09:43 PM
