Thread: Tapmatic on CNC mill?
05-06-2020 #4
You can see the g code around 7:00 in the vid. It's fairly simple I suppose. Being a Mercan, the units are inches:
S1000 (1000rpm in his example - he's not paying for any breakages)
(goto x,y hole position)
G1 Z-0.25 F12.5 (feed down to 1/4" below the surface - it started 1/4" above the surface from the previous operation)
G1 Z0.25 F25 (retract back to 1/4" above the surface)
(goto next x,y hole position)
etc
The tap he is using is a tiny gnat's cock thing with 80TPI ie 12.5 thou pitch, so at 1000rpm, the feed rate needs to be 12.5 (inches per minute). And the retract feedrate is twice that ie 25 (inches per minute).
I suppose the way to do it may be to write a little macro like the above and call it up using the manual NC option within Fusion CAM for each hole position? I don't want to manually type in the coords but I can't see how to make it happen from Fusion.
eBay: Quick-Step Mill QS 1000 QSM Hemingway kits John Payne, lathe mill head
By Boyan Silyavski in forum Items On eBay UKReplies: 0Last Post: 15-10-2018, 12:33 PM -
help needed - What CNC mill should I get to mill 7075 1off mountain bike parts?
By Benchmark-bikes in forum Machine DiscussionReplies: 3Last Post: 28-04-2017, 10:18 PM -
2x Tapmatic Tapping Heads
By andy_con in forum Classified Ads, Buy, Sell & SwapReplies: 0Last Post: 31-08-2015, 03:44 PM -
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
