I'm based in Suffolk and was recently given what amounts to a complete workshop, lathe, milling machine, literally tons of tooling, and a non-functional computer controlled engraving machine. The engraver is a Suregrave Rotation S and although it appears that the steppers and spindle are in good condition, the controller does not work. These machines had a bit of a reputation for being uncooperative and flaky in use and the manufacturer has long since disappeared so no support available. I have been in touch with someone who is an acknowleged expert on Suregrave stuff and his view is that it would be very expensive to repair and a better course of action would be to put together a new controller system.
I have very little knowledge of CNC systems but a good grounding in both small scale engineering and basis electronics. I'll be looking for advice and recommendations to enable me to convert this beast into a functional engraver. I'm not sure where the boundary is between straightforward engraving and CNC routing, I suspect the boundary is a bit blurred, but I'm assuming at this stage that this sytem could be controlled by Mach3, which has an engraving module, but I'm open to other suggestions!
Gordon
Convert the milling into a CNC machine
By jfroux_1 in forum Tool & Tooling TechnologyReplies: 0Last Post: 19-08-2018, 09:23 PM -
Commercial CNC machine lifespan?
By sarahloyd in forum Machine DiscussionReplies: 13Last Post: 24-01-2014, 02:21 PM -
Commercial Machine choices...
By jashington in forum Marketplace DiscussionReplies: 4Last Post: 10-10-2013, 10:38 AM -
convert traditional machine or build router?
By Henrik in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 22-03-2013, 08:49 AM
