    So onwards and upwards as they say.
    Material procured and I set off to turn rough cast blocks into some nice rectangular pieces . When I say “turn” I was being literal because the milling machine was tied up , and its high speed head would have been making sparks fly at 2000rpm, so my Colchester Bantam lathe was pressed into service to reduce the blocks to size and to bore good fitting locations for the ball nuts.
    In addition I needed to skim a larger seat for the “Y” nut so the toy Seig SX2 mill came into play too. I have to say that as a toy milling machine it made a pretty reasonable job, and in particular I found it was superb as a drilling machine when I came to drill and tap for the fixing bolts .
    The “X” nut block was a simple replacement, marked off and drilled using the old Alloy block as a template and jig. It barely cleared the underside of the table when fed from end to end , but by dressing a few high spots and lumps with the grinder, it then traversed freely. I may just take a light skim off the underside with the toy mill to ensure that nothing catches
    The “y” nut mounting was quite a lot more fiddly though, as I had to bore it fairly precisely in order to avoid shimming underneath it to align it with the ballscrew and nut . Nevertheless, and maybe more by good luck than good management , the nut slid quite easily into its bore with the block tight down onto its seat . Four M6 cap screws secured it firmly to the saddle and I intend to fit a couple of dowels for additional rigidity.
    So with the new blocks fitted this
    Becomes this
    And this
    becomes this
    All reassembled and now seems good and tight, so will now reinstate the homing switches , (I bought some more substantial ones from RS) adjust the settings in Mach 3, and give it a cutting test.
    I have to say that I am finding this very absorbing . Lockdown certainly has advantages when it comes to getting around to completing those projects which have been lying on the shelf for years .
    Then back to Cambam to see if I can make something useful happen
ID:	28392   Click image for larger version.
    So it is now working again after a few hicupps and alterations to settings.
    Not sure if any others will be tempted towards a similar project. Albeit it is an economic route to a CNC function if you already have a decent sized milling machine to begin with.
    I like the idea because (as I said above) it saves interfering with the mechanics and drives of an existing machine, and in particular where modifications might detract from the value of an older and possibly much sought after machine.
    I can easily unplug my table and set it aside if I want to use the machine as a manual mill. Or I can even do a manual manual job with the CNC compound in place, using the Deckel mill’s own feeds and traverses, although I do recognise that rigidity will be a problem for larger jobs.
    I always wondered, if I converted my machine to CNC then what would I do if I needed to do some simple conventional milling, but no problem here.
    The table has a pretty decent work area for a first machine, probably a bit larger than a typical Chinese first step machine, so probably an easier project than converting something like a Seig x2 or a base machine of that order. Table length is good so lots of space for decent size workpieces or even a fourth axis if you are tempted to go that far.
    I have proved to myself that I can build a budget CNC machine. In my case the total cost of parts was a tad under £500 , So pretty reasonable and no massive loss if it turns out that I lose interest (which I honestly can’t imagine)
    I have thoroughly enjoyed the project and learned a lot too. So I can be much more confident in starting a second and maybe much more robust project.
    I may move on to a larger table, hopefully one with more space, and better put together.
    I am tempted by this one which looks more up to the job, with taper gibs. It would be nice to see one in the flesh though to be able to assess general fit and finish.
    https://www.ebay.co.uk/itm/COMPOUND-...YAAOSw42JZLsWB
    It is not significantly taller than my first attempt so would certainly fit my on my Deckel table.
    This has certainly been a valuable project for me, a test bed to practice the skills which I am only beginning to grasp. I have certainly learned a lot in the process and it has been highly enjoyable as a project in itself. And as I hopefully progress to higher things, I will still have this as fall back option to test ideas. They say that “any old bike is good enough to practice on” so I will hang on to this even if I move to something more exciting.
    So if you are contemplating converting a sturdy old mill to CNC then I would certainly advocate this route. Not for everyone, but certainly works for me!
  1. Converion based upon my old Deckel Mill
    By John11668 in forum Milling Machines, Builds & Conversions
    Last Post: 01-06-2020, 09:44 PM
  2. CONVERSION: Conversion of an old milling machine using a CNC compound table
    By John11668 in forum Conversion Build Logs
    Last Post: 01-06-2020, 10:50 AM
  3. CONVERSION: Deckel maho dmu 50m cnc
    By toomast in forum Conversion Build Logs
    Last Post: 03-12-2019, 01:35 AM
  4. Sub-table for a Bridgeport mill...
    By Davek0974 in forum Bridgeport Milling Machines
    Last Post: 20-09-2016, 08:58 PM
  5. limits on mill table
    By John11668 in forum Gantry/Router Machines & Building
    Last Post: 31-08-2011, 06:46 PM
