Page 2 of 2 FirstFirst 12
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 2 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    With care, it seems that you can use woodworking power tools for aluminium. Certainly folks on this forum have used handheld routers to work Al. I've used my workworking bandsaw for Al as well - was a bit worried at first but take it easy with a suitable blade and it works OK.
  2. The Following User Says Thank You to Neale For This Useful Post:
  3. #12
    Axminster stock ready-made blades that would fit - e.g. these
    Axminsters best 10 tpi blade would not be great for aluminium.
    Mine is 18 tpi , but would have preferred 24.
  4. #13
    Don't woodworking bandsaws run too fast for metal?... there was one model, that I completely forget, that had a 1/2 speed gearing that a number of metal workers did recommend. Mind you - if it works for you then go for it - the throat on a 6x4 is very limiting for sheet/plate work.
    The old Sealey is intended for both and has speed change pulleys . Works superbly on 3,5, 6, and 8 mm plate . Havent tried on 10 yet but I would tend to buy that as slab and use the 6x4 for that.
    Has anyone found it puzzling how to get the teeth to cut downward on some saws
  5. #14
    I've got one of these primarily for wood but I have cut 12mm aluminium with it using the ordinary wood blade and was happy with the results. A dedicated metal blade would obviously be better and it does have pulleys for two speeds.
    Obviously this particular machine would incur significant delivery costs for you but there must be a Pommie equivalent available.
    https://www.machineryhouse.com.au/W952
  6. #15
    Mine has actually cut chinese glass scales down to size
    (but that probably would not be covered by the instructions)
  7. #16
    BDH's Avatar
    Lives in Mansfield, United Kingdom. Last Activity: 30-05-2021 Has been a member for 5-6 years. Has a total post count of 26. Received thanks 3 times, giving thanks to others 22 times.
    I have a Proxxon bandsaw that I use for model engineering. I do not use aluminium but I have used the Proxxon to cut 1/2" brass and mild steel flat bar. I have the blades made locally with 14TPI but the company would make them with any standard number of teeth. I use bimetal blades.
    Brian
  8. #17
    I bought an old 14" Startrite for £130, it has 5 pulley speeds and a two speed gearbox, so 10 in total. It's a heavy thing which pays when cutting aluminium and steel. I've re-sawn ash and oak up to 11" thick, very slowly.
    Only downside is that it needs an inverter as it's 3 phase.
  1. Metal Bandsaw or Cut-Off Saw?
    By Gytis in forum Metalwork Discussion
    Last Post: 18-01-2017, 08:36 PM
  2. Wiring a Bandsaw to VFD ? Speed?
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 18-08-2016, 11:53 AM
  3. Bandsaw Guides
    By PeteG in forum Marketplace Discussion
    Last Post: 17-10-2015, 02:38 PM
  4. Affordable bandsaw that's not cr@p
    By garson626 in forum Tool & Tooling Technology
    Last Post: 13-02-2014, 12:16 AM
  5. Multico Bandsaw
    By newtoid1986 in forum Marketplace Discussion
    Last Post: 13-04-2012, 09:17 PM
