    Quote Originally Posted by chillybo View Post
    Thanks Jazz,
    Mach3Mill.zip
    Hope I've attached the zipped XML file and not something else.
    I altered home and limits to the new settings that should be showing on the XML file and it now works. Problem is that if I alter the home speed above 3% the machine makes an awful noise and the gantry doesn't move. The noise is high pitched and changes depending on the home speed. It doesn't sound like when a stepper motor stalls.
    Thanks Chris
    Didn't work not seeing any thing in the zip
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #2
    Jazz and folks, here's a couple of pictures - home limit screen and motor tuning screen - if that's got anything to do with it.
ID:	28363Click image for larger version.
    What units are you using Metric or imperial.?
  6. #4
    metric
  7. #5
    metric
    Did you see Jazzcnc quote "Didn't work not seeing any thing in the zip" How can anybody help with one word answers.
    I would suggest have another go at posting the XML file and checking it works you might be able to post it by changing the file name by adding .txt to the end of the file name. ie Mach3.xml.txt
  8. The Following User Says Thank You to Clive S For This Useful Post:
  9. #6
    metric
    Ok well your motor tuning is setup for imperial.!
    To set up correctly you need to know the screw pitch and the micro-steps set on drives. Divide the micro-steps by the pitch and this is your steps Per setting. If you have any ratio on the motor then you'll need to factor that in as well.
    The velocity and acceleration you will have to set according to the machine by adjusting until motors stall then back them off 25%. Vel =2000 Accel=500 is a good starting point if you are unsure. If a router can't do those speeds it's not much use as a router.!!
  10. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. Proximity limit switch problems
    By davrich in forum General Electronics
    Last Post: 12-03-2018, 01:58 PM
  2. 3 pin npn LJ12A3-4-Z/AX proximity switch help
    By RobC in forum General Electronics
    Last Post: 14-08-2017, 07:50 PM
  3. 3 wire proximity switch help
    By mikem in forum General Electronics
    Last Post: 06-10-2015, 03:24 AM
  4. Proximity switch NPN or PNP
    By Matt81 in forum General Electronics
    Last Post: 19-04-2014, 11:38 AM
  5. FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
    By Shinobiwan in forum Items For Sale
    Last Post: 02-02-2013, 10:54 AM
