    3mm wall is too thin use 5mm on all steel sections.
    Only use 12Nm Nema 34's if your using Mains voltage drives. If you don't use high voltage they will be slow.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Thanks for the info.
    I must admit the electronics part is what worries me most about the project, I keep putting off the research
    What's the reason for 5mm, extra rigidity or resonance?
    Quote Originally Posted by scott88 View Post
    Resonance mainly, rigidity comes from frame design mostly but there are other advantages like more material for threads.
    Yeah, I was thinking of at least 5-6mm for anything that will hold a rail and 3mm for the rest, mainly for budget. I've seen people filling with sand, so maybe I could do that for dampening the high frequencies?
  1. Some General CNC Advice
    By Docara in forum General Discussion
    Last Post: 17-09-2018, 05:21 PM
  2. 8*4 ,3 axis pointers.
    By voyager1972 in forum Machine Discussion
    Last Post: 15-06-2015, 04:57 PM
  3. 9x20 lathe conversion, pointers wanted
    By Stupoty in forum Gantry/Router Machines & Building
    Last Post: 31-12-2014, 08:40 PM
  4. Vacuum bed general questions
    By racerbear02 in forum Woodwork Discussion
    Last Post: 23-10-2014, 09:12 PM
  5. Fanuc, any one know this well, need pointers/help
    By fastcarl in forum Machine Control Software
    Last Post: 26-08-2011, 07:46 AM
