	18-06-2020 #1
Hi all, Im relatively new to CNC so I could be making an obvious mistake here!
I have a Fanuc controlled Harrison 330 Alpha lathe, its a great machine being very versitile but Im having trouble with setting the Z workshift in full CNC mode. There is no G54 active on this machine.
To set the workshift I call up the first tool T0101 in mdi and the set the position I want Z 0 with that tool, I then go to workshift and input Z0, when I then command T0101 Z 0 in mdi the postion of the tool goes to Z -33.295 which happens to be the offset of tool 1, consequently if I then repeat the process of setting the workshift as before it works fine and goes to the correct tool 1 Z 0 position!, and will from there on unless the computer is restarted! Obviously this will cause a crash if I run a program. I could/ very likely be doing something wrong procedurely or possibility setting tooloffsets incorrectly. Id post some pictures of the screen but not sure how to.
Any guidance appreciated on what the problem might be.Last edited by Sucram; 18-06-2020 at 11:53 AM.
Harrison Alpha 330 lathe Fanuc 21it SRAM back up problems
By Sucram in forum General DiscussionReplies: 14Last Post: 24-02-2021, 03:44 PM -
Harrison Alpha 330 lathe Fanuc 21it Work offset and Work shift problems
By Sucram in forum General DiscussionReplies: 0Last Post: 15-12-2019, 09:44 PM -
keyboard interface problem (Denford lathe)
By asto in forum Denford LathesReplies: 0Last Post: 29-07-2015, 06:38 PM -
FANUC 10TF Profiling problem
By macca5 in forum Programmers CornerReplies: 1Last Post: 06-12-2011, 12:47 PM -
got a problem cant find belts for lathe
By Scott in forum Machine DiscussionReplies: 4Last Post: 08-09-2010, 01:35 PM
