Page 2 of 2 FirstFirst 12
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by joey View Post
    My table is 2700mmx1400mm. Yeah its my firsh attempt. Im running mach3 however i have read that linuxcnc and mach4 can control THC using the divided plasma voltage as an input to the board as opposed to running a separate THC unit. This would be a slicker solution i believe? Who has done it that way? What breakout board would best suit this solution? Yeah i love the AE86 haha
    Did you read post #4 and #8
    joey's Avatar
    Lives in Ballycastle, United Kingdom. Last Activity: 19-06-2020 Has been a member for 4-5 years. Has a total post count of 5.
    Hi Clive, your machine looks impressive, i would like to try a similar setup, but i have never used linux, i have a few old desktop i could try it on. What are you using as a post processor?
    Have a read through this https://forum.linuxcnc.org/plasmac .
    https://forum.linuxcnc.org/plasmac/3...-documentation
    Also this is the easy way to get linuxcnc
    https://forum.linuxcnc.org/9-install...int-iso#165631
    This is the above in action; https://www.youtube.com/watch?v=d0s6sI7IvuY
    download the iso and use windisk to make a boot usb
    joey's Avatar
    https://eusurplus.com/index.php?rout...&product_id=50 is this the board i require?
  5. #15
    How can a guess what you require when I don't know what you are going to build. I have said in #4 what Mesa cards I used.
    You have linked to a 7i76e which you can use as well but the 7i96 is cheaper and more suited for plasma but it depends how many inputs and out puts you require.
    you will also need a THC-10.
    Eusurplus is a good company.
    Did you read through the docs I posted
