Thread: Hi From Ballycastle
Hi Clive, your machine looks impressive, i would like to try a similar setup, but i have never used linux, i have a few old desktop i could try it on. What are you using as a post processor?
19-06-2020 #2
Have a read through this https://forum.linuxcnc.org/plasmac .
https://forum.linuxcnc.org/plasmac/3...-documentation
Also this is the easy way to get linuxcnc
https://forum.linuxcnc.org/9-install...int-iso#165631
This is the above in action; https://www.youtube.com/watch?v=d0s6sI7IvuY
download the iso and use windisk to make a boot usbLast edited by Clive S; 19-06-2020 at 10:25 AM.
19-06-2020 #3
https://eusurplus.com/index.php?rout...&product_id=50 is this the board i require?
19-06-2020 #4
How can a guess what you require when I don't know what you are going to build. I have said in #4 what Mesa cards I used.
You have linked to a 7i76e which you can use as well but the 7i96 is cheaper and more suited for plasma but it depends how many inputs and out puts you require.
you will also need a THC-10.
Eusurplus is a good company.
Did you read through the docs I posted..Clive
