19-06-2020 #11
If the disk is to have any holes in it you can clamp the blank, drill the holes and screw it down through those. Remove the outer clamps and away you go.
19-06-2020 #12
21-06-2020 #13
I generally use a pocket on a spoil board like wot Jazz said, but I also have 3D printed some plastic 2-4-8 blocks with M6 threads in them and clamp these onto the T slots and use grub screws or long nylon cap head screws in the horizontal threaded hole to apply clamping force. That way no steel to chew the cutter.
Aren't those Mitee Bites expensive !
The Following User Says Thank You to cropwell For This Useful Post:
21-06-2020 #14
21-06-2020 #15
23-06-2020 #16
Slightly off from what you need, but I made these cam clamps on Sunday just to try out the idea. They are based on a design from Marius Hornberger on YouTube but I'll design my own if I decide to mass-produce them. To make sure they dont slip I fix them to the base with an M8 bolt, just loose enough to turn then lock them down once in place. Worked OK holding the test piece for surface skimming with a 22mm tool and being quick and easy to make from scraps of wood they can be treated as sacrificial.
The most stupid Newbie question ever!!
By mattscarlett in forum General DiscussionReplies: 7Last Post: 30-06-2016, 08:09 PM -
Newbie computer hardware question
By chris in forum Computer HardwareReplies: 4Last Post: 16-01-2014, 05:12 PM -
NEW MEMBER: Newbie - question on bit types
By Steven W in forum New Member IntroductionsReplies: 2Last Post: 16-05-2013, 12:06 PM -
newbie with a tool id question
By bigmatt-s2rst in forum Tool & Tooling TechnologyReplies: 2Last Post: 03-10-2011, 06:16 AM -
Newbie Question ...
By Wobblybootie in forum General DiscussionReplies: 1Last Post: 03-12-2009, 05:32 PM
