    This is my first forum post so first of all, hello everyone! I am at the stage of building the first cnc plotter, quite large and heavy as for the first machine (about 1.8m x 0.8m) and I would be very grateful if you could help me with electronics. Quite a long time ago I inherited second-hand electronics, theoretically complete set, after amateur coversion of a mini milling machine, although I have problems with it and I hope that this is my lack of knowledge. I would love to use as many components already bought as possible .. but to the point:
    Breakout board - CNC4PC model C1
    1. The motors do not spin despite the fact that Mach software shows movement using the arrows on the keyboard. The motor is locked, it cannot be turned. There are diodes on the breakout board, it seems to me dedicated to outputs, not activated, only the 'outputs status' diode is on, what should I check step by step to verify if the board is ok?
    2. How to check if the drivers are ok? The voltage is fine, 42V on each of them. The voltage between A + and A- and B + and B- in the case of one motor connected is 1.7V, in the other 1.4V. Where there is no motor connected, 42V between A + and A-. Is this correct?
    I would have more questions, but for now, the most important is to verify whether the board and drivers are in full working order and configured with Mach3. The attached photos show Mach3 settings, previously configured with current set up. Thanks in advance for your help, I will post a full 3D project and a schematic after completing the project here. I’ll post more details about my design soon.
    Regards!
ID:	27845   Click image for larger version.
ID:	27846   Click image for larger version.
ID:	27847   Click image for larger version.
  1. New CNC build gantry questions
    By Capsuna in forum Gantry/Router Machines & Building
    Last Post: 04-12-2019, 12:59 AM
  2. BUILD LOG: 1800 x 1500 x 500 work area CNC build log
    By marbles in forum DIY Router Build Logs
    Last Post: 17-10-2018, 01:53 PM
  3. Beginner MYCNCDIY Mill Build questions
    By suraj1793 in forum Gantry/Router Machines & Building
    Last Post: 15-11-2014, 06:28 PM
  4. A few questions before I start my build
    By eclassic in forum General Discussion
    Last Post: 11-07-2011, 10:54 PM
  5. NEW MEMBER: Hi from rainy York - build plans/questions
    By bikepete in forum New Member Introductions
    Last Post: 11-10-2009, 07:43 AM
