Lots of help on the dedicated forum https://forum.freecadweb.org/viewfor...c1c8839193ee32 . This topic in particular will be of interest https://forum.freecadweb.org/viewtopic.php?f=15&t=25595 .
In short,you need to select the body then click on the icon that creates a path job object.It helps if in preferences you select job preferences and set them accordingly.You will have to create the tools you intend to use and create a controller for each of them.Select the machining strategy you intend to use and select the surfaces,set the parameters to suit and then the toolpath should appear.
CONVERSION: Half baked CNC mill
By John11668 in forum Conversion Build LogsReplies: 3Last Post: 26-05-2020, 10:42 PM -
Half complete Triac conversion needing some advice.
By Dan-27 in forum Milling Machines, Builds & ConversionsReplies: 20Last Post: 05-01-2020, 11:32 PM -
NEW MEMBER: Solar Sphere / Solar Magnet Engine
By wolfram-g in forum New Member IntroductionsReplies: 7Last Post: 11-08-2018, 09:17 AM -
diyCAM: Carve Released – Half off ($25) for first 50 customers!
By Chemeleon in forum Manufacturer NewsReplies: 0Last Post: 19-08-2013, 12:46 AM -
WANTED: Boxford Imperial Lead screw + Half nut
By rnr107 in forum Items WantedReplies: 0Last Post: 26-12-2010, 10:01 AM
