Thread: best stepper driver???????
	24-03-2013 #11Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
	24-03-2013 #12
What rating or output is your PSU, if you dont want to change that as well then you need to match your drivers to that so they dont go pop!, consider if or not you plan to upgrade or use the new drivers on another machine in the future.
.MeLee
	24-03-2013 #13
output on PSU is 24v 8.3A 50-60hz /http://www.interinar.com/fs-20024-1m.html
na I wont be using on another machine.Last edited by dudz; 24-03-2013 at 02:57 PM.
	24-03-2013 #14
The Following User Says Thank You to Lee Roberts For This Useful Post:
	24-03-2013 #15John S -
	24-03-2013 #16
Why are they better? are they not overkill for what he needs and his PSU being only 24v ? What about the duty if they get seen coming in?
.MeLast edited by Lee Roberts; 24-03-2013 at 03:51 PM. Reason: changed from amps to volts
	24-03-2013 #17Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
	24-03-2013 #18
The Zones are for postage.
.MeLee
	24-03-2013 #19
Yes they are overkill but being overkill means they are not running flat out and plenty in reserve.
Plus they are in a case, post paid and cheaper.
That M542 design has been proved over many 100's of thousands of units built.
I have bought loads of these, none have ever hit the radar, usually they get declared as a USB cable at $10John S -
The Following User Says Thank You to John S For This Useful Post:
	24-03-2013 #20
Patrick,
Have a look here: Enclosures, you could also get a System4 board and build yourself a nice control box to house everything :).
Just an idea
.MeLee
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper Driver requirements?
By Dwayne Dibbley in forum Motor Drivers & ControllersReplies: 3Last Post: 24-07-2013, 05:29 PM -
stepper driver tester
By ptjw7uk in forum Motor Drivers & ControllersReplies: 2Last Post: 24-06-2013, 05:48 PM -
Which stepper driver
By Colin Barron in forum Motor Drivers & ControllersReplies: 0Last Post: 25-09-2010, 08:33 PM -
connecting stepper driver to PC
By berkut in forum General ElectronicsReplies: 2Last Post: 10-06-2009, 09:25 PM
