    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    This is all I can find.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
    What rating or output is your PSU, if you dont want to change that as well then you need to match your drivers to that so they dont go pop!, consider if or not you plan to upgrade or use the new drivers on another machine in the future.
    .Me
    dudz's Avatar
    output on PSU is 24v 8.3A 50-60hz /http://www.interinar.com/fs-20024-1m.html
    na I wont be using on another machine.
    How about some of these: DRV30/S the tec doc is here for these as well.
    Should be nice for a 4 wire bipolar motor, cheap, well made and very good support from Roy if anything was to go wrong.
    .Me
  5. The Following User Says Thank You to Lee Roberts For This Useful Post:
  6. #15
  7. #16
    Why are they better? are they not overkill for what he needs and his PSU being only 24v ? What about the duty if they get seen coming in?
    .Me
    Last edited by Lee Roberts; 24-03-2013 at 03:51 PM. Reason: changed from amps to volts
    dudz's Avatar
    What is Zone 1 and Zone 2 ?
    It looks good but the circuits have no cases. So I would have to build something.
    .Me
  9. #18
    The Zones are for postage.
    .Me
  10. The Following User Says Thank You to Lee Roberts For This Useful Post:
  11. #19
    .Me
    Yes they are overkill but being overkill means they are not running flat out and plenty in reserve.
    Plus they are in a case, post paid and cheaper.
    That M542 design has been proved over many 100's of thousands of units built.
    I have bought loads of these, none have ever hit the radar, usually they get declared as a USB cable at $10
    John S -
  12. The Following User Says Thank You to John S For This Useful Post:
  13. #20
    Patrick,
    Have a look here: Enclosures, you could also get a System4 board and build yourself a nice control box to house everything :).
    Just an idea
    .Me
  14. The Following User Says Thank You to Lee Roberts For This Useful Post:
  1. Replies: 1
  2. Stepper Driver requirements?
    By Dwayne Dibbley in forum Motor Drivers & Controllers
    Last Post: 24-07-2013, 05:29 PM
  3. stepper driver tester
    By ptjw7uk in forum Motor Drivers & Controllers
    Last Post: 24-06-2013, 05:48 PM
  4. Which stepper driver
    By Colin Barron in forum Motor Drivers & Controllers
    Last Post: 25-09-2010, 08:33 PM
  5. connecting stepper driver to PC
    By berkut in forum General Electronics
    Last Post: 10-06-2009, 09:25 PM
