Thread: best stepper driver???????
25-03-2013 #26
Ok.... I bought 3 of these , CNC Micro-Stepping Stepper Motor Driver 2M542 Bi-polar 2phase 4.2A Switch | eBay and I bought this ; 3 axis CNC USB Card Mach3 Breakout Board Interface 200KHz windows2000/xp/vista | eBay
I could of bought the cheap one but I really like the idea of using the USB instead of the PP port. I will let you know how I get on. Thanks both of you for all of your help.Last edited by dudz; 25-03-2013 at 09:42 PM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
The Following User Says Thank You to dudz For This Useful Post:
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper Driver requirements?
By Dwayne Dibbley in forum Motor Drivers & ControllersReplies: 3Last Post: 24-07-2013, 05:29 PM -
stepper driver tester
By ptjw7uk in forum Motor Drivers & ControllersReplies: 2Last Post: 24-06-2013, 05:48 PM -
Which stepper driver
By Colin Barron in forum Motor Drivers & ControllersReplies: 0Last Post: 25-09-2010, 08:33 PM -
connecting stepper driver to PC
By berkut in forum General ElectronicsReplies: 2Last Post: 10-06-2009, 09:25 PM
