Thread: best stepper driver???????
26-03-2013 #31
Shouldn't be taken into account the motor amps/torque vs. the machine weight/working material?
If I put 3A motors on a belt driven PCB milling machine it is impossible to use that power assuming to have idle-current reduction.
I think the 60% rule for the power supply works only with toroidal transformers which have an instantaneous power at least 25% higher than the nominal, and with one PSU for all motors because it is unlikely to have all axis under high loads at the same time.
John, what rated current had the motors and drives for your conversion where you used reliably a 400VA transformer?
26-03-2013 #32
Joe,
Truthfully can't answer this question at this time.
Using laptop with parallel port is a no no but the USB card 'should' be OK.
So far although we have two cards neither has been tested because I'm in the process of converting a manual mill to CNC and it will be used on this, probably about 2 weeks away from testing given this has to fit in with my regular work.
It will be tested on a Dell to start as the 'test bench ' is so equipped but I'm also interested in seeing if the laptop will run it OKJohn S -
26-03-2013 #33
Part of the reason for your low readings is the sample frequency of the clamp meters is low relative to the frequency of the current the motors are drawing, so it tends to miss the peaks and generally not be reliable, especially if the meter is not true-rms. An oscilloscope reveals a lot more.
However, it is still true to say the rms current, and therefore power drawn, is substantially lower than the 2/3rds 'rule' implies. It's easy to show why - just look at the motor ratings to work out the power. For example the common 3Nm motors require 4.2A and 2.73V. Power is current multiplied by voltage, so P=4.2*2.73=11.466W. That's per phase though, and it's a two phase motor, so 2 times that which gives 23W. You're driving it from about 70V, so the current is pulsed such that the mean power does not exceed this rated power. Same formula again, so the mean current is I=P/V=23/70=0.33A.
That's why you see a low current (about 0.33A) per motor, not 4.2A or some significant fraction of that. The reason it helps to have the power supply rated for quite a lot more (i.e. 2/3*4.2) than this anyway is that the peak currents can be substantially greater, so you need a transformer capable of delivering that. That's not the only way to solve it though.Last edited by Jonathan; 26-03-2013 at 02:13 AM.
The Following User Says Thank You to Jonathan For This Useful Post:
27-03-2013 #34
17-04-2013 #35
17-04-2013 #36
Still 2 weeks away <g>
Problem is my day job is emergency repairs and I never know what comes thru the door to upset planned jobs.
Starting to wire the box up Friday, fingers crossed and then sort the machine out.
machine is all converted mechanically, just need covers and bellows re fitting.John S -
17-04-2013 #37
OK be glad to hear when you get it up and running. Cheers
21-04-2013 #38
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper Driver requirements?
By Dwayne Dibbley in forum Motor Drivers & ControllersReplies: 3Last Post: 24-07-2013, 05:29 PM -
stepper driver tester
By ptjw7uk in forum Motor Drivers & ControllersReplies: 2Last Post: 24-06-2013, 05:48 PM -
Which stepper driver
By Colin Barron in forum Motor Drivers & ControllersReplies: 0Last Post: 25-09-2010, 08:33 PM -
connecting stepper driver to PC
By berkut in forum General ElectronicsReplies: 2Last Post: 10-06-2009, 09:25 PM
