Thread: best stepper driver???????
Hi All
Big question I know,but just wondered what every one is using.
I had hoped to modify an old driver board but that went up in smoke tonite, which has shown me how difficult it is to fault find on a single board and has put me off getting one of the "all in one boards" from china
I need 3 axis to drive 2 phase bipolar motors wired in parallel at 2 amp per phase, any ideas?
I use Motion Control Products MSD542 drives. They have worked fine for around a year now.
http://www.motioncontrolproducts.co....&products_id=3
26-11-2009 #3
Arc sells the same driver cheaper and it includes VAT.
http://www.arceurotrade.co.uk/Catalo...tepper-DriversJohn S -
26-11-2009 #4
Are they the same driver John ? or the PM range ?
i'm using MSD542 as well, i'v used the routoutcnc drivers as well.
26-11-2009 #5
I use the Motion Control Products MSD542 ones, I think they are made by Leadshine in China (M542 OEM model) and sold under different brandnames
Leadshine m542
26-11-2009 #6
They are not the same driver, close but not the same.
As allways in china you will find copies of everything.
Leadshine are the largest manufacture of stepper drivers in china, and there are lots of copies of their drivers, some good, some not.
by the way i will match Arc euro trade prices as long as i have them in stock.
You may also want to try our PM752 for higher current motors, it is a very good driver and goes all the way up to 70V.Visit Us: www.automationshop.co.uk
24-03-2013 #7
Hi Lee,
My all in one packed up ages ago, and put me off finishing my machine. I have decided to give it another go now. All I am missing is the motor drivers. Do these boards work with Probotix H23 - 400 4 wire motors ?. Thats all the info on the motors. I didnt buy them myself.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
24-03-2013 #8
What ones? Can you not email them and get the spec sheet for the motor, i found the 8 wire version: HT23-400-8.pdf, most drivers will run motors but you want to match them really.
.MeLee
24-03-2013 #9Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
24-03-2013 #10
What rating or output is your PSU, if you dont want to change that as well then you need to match your drivers to that so they dont go pop!, consider if or not you plan to upgrade or use the new drivers on another machine in the future.
.MeLee
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper Driver requirements?
By Dwayne Dibbley in forum Motor Drivers & ControllersReplies: 3Last Post: 24-07-2013, 05:29 PM -
stepper driver tester
By ptjw7uk in forum Motor Drivers & ControllersReplies: 2Last Post: 24-06-2013, 05:48 PM -
Which stepper driver
By Colin Barron in forum Motor Drivers & ControllersReplies: 0Last Post: 25-09-2010, 08:33 PM -
connecting stepper driver to PC
By berkut in forum General ElectronicsReplies: 2Last Post: 10-06-2009, 09:25 PM
