    Hi Doddy, yes it is a Fotek ac/dc ssr with a switching voltage between 3 and 30v dc, I had it wired to p16c/p16e of bob and when I toggle it on/off in uccnc the led would come on and off.
    The ssr was wired to a ac chassis socket to plug kress spindle into, but when the ssr was switched off I measure voltage across the chassis socket pins and was shocked to see I had 246v when it was supposed to be off and in an open state, I even disconnected the dc supply just to make sure it wasn't getting any voltage from the bob and it still showed 246v.
    A quick Google search and I discovered that other people have had similar issues with them failing closed unlike a mechanical relay.
    Yes I see what you mean now by using onboard relay to control the external relay used to switch ac power so will give that a go and fingers crossed I'll be successful!
    Many thanks for your time I'll let you know how I get on.
    Sent from my COR-L29 using Tapatalk
    Doddy's Avatar
    Quote Originally Posted by derekm06021970 View Post
    Be interesting to repeat that with a proper load (I assume you threw a DVM across the terminals?), you'll probably find a snubber circuit across the switching triac in the SSR to drop the switching noise - and the DVM will see the nominal terminal voltage. Add a load you *might* find that the voltage drops towards zero. Of course, the SSR could also be buggered.
    But... relay... KISS.
  1. Laptop for connecting to CNC?
    By MCmec in forum Tool & Tooling Technology
    Last Post: 17-01-2020, 10:26 PM
  2. Replies: 5
    Last Post: 04-02-2016, 08:51 PM
  3. Connecting VFD
    By andrew583 in forum Spindles & Drive Motors
    Last Post: 19-08-2014, 01:01 AM
  4. Relay V Contactor
    By GTJim in forum General Electronics
    Last Post: 18-03-2014, 10:10 AM
  5. need CAM that outputs g2g3
    By chris in forum CAD & CAM Software
    Last Post: 28-02-2014, 09:16 PM
