Thread: SCM Tech 95 CNC Machine
Hi thanks for the reply, that's great to hear. Have done some research and seen this is possible... I did forget about the dreaded 1.4Mb file limitations, how did we manage in those days! Thanks again, nice to see this is an active forum.
30-06-2020 #2
It will depend on the controller fitted but usually, you can drip feed code thru the RS232 using DNC software. Obviously the controller will need to have this function fitted or turned on in its parameters and you'll need the software. Now getting the software might be another story if it's an old controller.?
The other thing is that if you are wanting to run modern tool paths, esp 3D paths like relief carvings, etc that can have huge file sizes it might not be idle because of controller memory size so drip feeding will be restrictive on processing times and can be unreliable. Often these older machines are perfect for retrofitting with a modern controller because the machines are still good but controllers are from the stone age and restrictive if wanting to use modern Cam software/ toolpaths.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
FOR SALE: IFL i-TECH Cut 40 For Sale
By Bladevane in forum Items For SaleReplies: 0Last Post: 26-10-2019, 11:16 AM -
Opportunity for CAD/CAM Workshop Engineer/Technician in London at Med Tech Startup
By aot in forum Opportunities Available & SoughtReplies: 0Last Post: 25-01-2016, 11:46 AM -
scm tech 95l cnc machining centre User manual or parts lists
By george uk in forum SCM Group RoutersReplies: 13Last Post: 28-04-2015, 08:18 AM -
Jinan XYZ-Tech Ltd
By Jayman in forum General DiscussionReplies: 10Last Post: 07-12-2010, 12:54 PM -
NEW MEMBER: OneCNC Tech Support
By Gilly in forum New Member IntroductionsReplies: 6Last Post: 15-05-2009, 06:05 PM
