    I assume as it's possible to cut these with a TCT handsaw, doing it on the CNC would be no problem - but does anyone have any ideas of things like best tooling, spindle speed and DOC/feedrates please? cheers.
    Lives in Plymouth, United Kingdom. Last Activity: 11 Hours Ago Has a total post count of 1,746. Received thanks 297 times, giving thanks to others 11 times.
    Is an Aztec calendar on the cards?
    Sadly not - just some arkward shaped bits of "stonework" for the house.
    What type of block ?
    Are they lightweight Celcon or similar ?
    If it's not a big job you will be able to machine Celcon with ordinary TCT cutters, you will have to play /experiment with feed and speed.
    Fag packet sketch would be helpfull.
    Regards
    Mike
    Yes Mike, Celcon Standard or Solar grade blocks or equivalent. I don't have any sketches yet, but basically its curved top bits and side trims for arched top windows/doorways. Maybe I'll buy a cheap cutter or two and see how I get on - it will mean improving the dust covers on the machine a bit too, as I can see this would generate A LOT of dust, and abrasive dust at that - that was always on the list of improvements to do anyway.
  1. FOR SALE: Snowcrete Concrete - 14 x 25 KG Bags
    By Chaz in forum Items For Sale
    Last Post: 13-04-2019, 04:32 PM
  2. FOR SALE: 2 4 6 Blocks
    By johnsattuk in forum Items For Sale
    Last Post: 08-01-2019, 05:08 PM
  3. concrete base
    By reefy86 in forum General Discussion
    Last Post: 04-12-2017, 09:55 AM
  4. Bearing Blocks
    By GTJim in forum Rails, Guideways & Bearings
    Last Post: 15-01-2013, 07:18 PM
  5. Terminal blocks
    By Rogue in forum General Electronics
    Last Post: 19-09-2012, 11:01 PM
