Thread: Long tools
01-07-2020 #1
Can anyone recommend a spiral bit for pocketing and profiling hardwood at depths of up to 60mm? I’ve been using a straight bit which is ok but not that happy with the results which need a bit of sanding. I think a spiral bit would do a better job at reducing chatter but struggling to find an (affordable) bit at this length which will fit my er20 collet. Also when profiling at this depth the channels get clogged up with chips even with the vacuum on!
01-07-2020 #2
Has anyone bought carbide bits from Rennie Tools in Manchester?
01-07-2020 #3
i haver some of their 3mm down cutters. quality is good. was actually thinking of buying some of their compression bits soon too
01-07-2020 #4
01-07-2020 #5
yes. cant complain at their price. i bought two of their 3mm down cutters for 3mm abs sheet. probably done a couple of thousand meters full diameter full depth cuts, and its sharp as ever. havent used the second one yet.
The Following User Says Thank You to johngoodrich For This Useful Post:
01-07-2020 #6-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
01-07-2020 #7
https://www.rennietool.co.uk/collect...19797882306633
This was what I was looking at - 10mm sounds king of narrow though for a 63mm cutting length?! Shame they don’t have any 12mm at that length.
01-07-2020 #8
I've just bought a couple of their carbide downcut 2mm and 1mm endmills. Giving a very nice finish.
01-07-2020 #9
How about one of these
https://www.rennietool.co.uk/collect...ra-long-series. It will cut wood fine. Might have to cut the coal down a bit
01-07-2020 #10
*oal bleddy autocorrect
FOR SALE: SFU1605 Ballscrew & nut - 1150mm long & 750mm long - BK/BF12 end machined - £20 each
By Maccydu in forum Items For SaleReplies: 2Last Post: 21-09-2017, 06:12 PM -
how long should a bit last ?
By Blackrat in forum Woodwork DiscussionReplies: 3Last Post: 21-12-2014, 12:04 PM -
WANTED: 2 nema 23's 76mm long dual shafts 6.35mm plus one 56mm long nema 23 dual shafgt 6.35
By nobby in forum Items WantedReplies: 0Last Post: 24-09-2014, 09:57 AM -
How long
By Jester in forum General DiscussionReplies: 1Last Post: 04-01-2014, 03:16 PM -
At Long Last!!
By Wobblybootie in forum DIY Mill Build LogsReplies: 9Last Post: 11-08-2010, 12:58 PM
