Hi , i have just started using a rye twin head cnc router , I’ve not much experience with it and was after advice on setting the depth of the cutter. The control panel on the machine is a omicron 3000.
1. First of all I went into the ‘toolbox ‘on the panel ,
2. M/attr
3 .lenth dia
4.head select.
5 this will lower the head (3)
6 back to lenth dia
7 this now will show ‘ tool 3 L/ offst
8 I now use the left hand buttons to lower the head to required height , then press F1 to set the height.
It will set now to the Z depth .
9 I now press esc and the Z depth has went back to 1500,
So I can’t seem to change the depth from the control panel . I’m sure I’m just missing something out . Any advice on how to do this .
18-07-2020 #2
Hi Sean,
I've also got a rye twin head CNC just started to try and get it running....
Maybe put your post in the Rye category?
Sent from my Mi A1 using Tapatalk
20-07-2020 #3
Thanks, having a look now
18-07-2020 #4
https://r.tapatalk.com/shareLink?url...&share_type=sf
19-07-2020 #5
What software/setup are you using?
20-07-2020 #6
Hi Sean,
Can you tell me which software you are using?
And is your pc connected to the controller via an rs232 serial lead.
Thanks Derek
29-07-2020 #7
Did you get this sorted?
what was the fix?
thanks
80mm Insert cutter face mill advice
By northmeade in forum Tool & Tooling TechnologyReplies: 3Last Post: 09-09-2017, 09:37 PM -
Hypertherm plasma cutter advice.
By T0rnado69 in forum Plasma Table MachinesReplies: 11Last Post: 17-06-2016, 09:53 PM -
solidoworks tapped thread depth and blind hole depth
By reefy86 in forum CAD & CAM SoftwareReplies: 2Last Post: 10-11-2015, 04:14 PM -
fly cutter advice please
By luke11cnc in forum Tool & Tooling TechnologyReplies: 13Last Post: 07-12-2014, 01:38 PM -
Trigonometry help please, plunge depth for a v cutter!
By cncJim in forum Tool & Tooling TechnologyReplies: 13Last Post: 06-11-2013, 03:41 PM
