Thread: Help a noob plan a build please
08-07-2020 #6
You can build a perfectly fine machine first time provided your willingness to do the research and listen to good advice. The trick is weeding out the good advice of expereinced builders from the ARM chair builders who mostly talk shite.! . . . Fortunately you have come to the correct place because most on here are either experienced builders or part time builders who have done the research but not quite reached the end yet. We don't have much time for the Arm chair builders here.!!
Not a chance of building a machine this size properly for £2.5k. You'll be lucky to build it for £4k and it will be more like £5k when finished. Don't try to do it on the cheap because it never ends well and often ends up costing you more in long run to get it working right or worse pisses you off and the job stops.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
BUILD LOG: Eyeballs and comments sought for noob build
By danilius in forum DIY Router Build LogsReplies: 20Last Post: 02-04-2017, 11:40 PM -
NEW MEMBER: Hi all, Ive got a plan, hopefully its a good one!
By Benja in forum New Member IntroductionsReplies: 6Last Post: 25-06-2016, 12:58 PM -
NEW MEMBER: Total noob about to embark on a build.
By Wal in forum New Member IntroductionsReplies: 6Last Post: 21-12-2012, 02:48 AM -
noob first build
By japcarmaniac in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 13-03-2012, 11:56 AM -
So... what do you plan to do over the hols?
By irving2008 in forum General DiscussionReplies: 5Last Post: 23-12-2008, 09:03 PM
