Thread: CNC mach spindle not spinning
Thanks Guys!
It's quite easy to have down moments in the current crazy sliver of humanity's history, but just seeing the wonderful response from multiple forum members all trying to help solve Bernard's dilemma has helped restore my faith in humanity!
And I've no doubt you will also ultimately help put Bernard onto the right track.
Cheers, Andy
17-07-2020 #42
Bernard - just a cautionary note - I'd personally review the controller settings before following the instructions to configure - one of the first program settings resets the controller to factory - so you would lose any pre-configuration by the OEM. Perhaps review the settings and get them copied down somewhere useful. The post from Cropwell - I'd seen it earlier but was a bit nervous of the reference to 110V operation - so proceed with care.
17-07-2020 #43
I share your apprehension. I don't know how VFD specific the parameter settings are. I know that some manufacturers deliberately go against de-facto standards (in other areas of electronics). I would recommend trawling through the settings to note down what the OEM set them to and compare with the list I found.
Connect spindle to mach
By Duffman in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 14-07-2020, 06:08 AM -
Spindle won't run using mach 3
By ryanjgreen in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 20-10-2019, 06:44 PM -
Spindle not spinning and got warm to touch
By Palletlad in forum General ElectronicsReplies: 3Last Post: 29-06-2019, 06:47 PM -
CNC 3040T-DJ Router spindle won't stop spinning
By Chilli in forum Chinese MachinesReplies: 5Last Post: 19-11-2016, 01:33 AM -
Problem with Spindle not spinning
By Noplace in forum Spindles & Drive MotorsReplies: 4Last Post: 22-01-2016, 02:40 PM
