Thread: CNC mach spindle not spinning
16-07-2020 #31
Why would you use that when it's clearly a completely different control box to what you have.? Just because it's called 3040 doesn't mean they are all the same.!
You need the relevant docs to the control box you have. In any case that type of document wouldn't be any use for checking the VFD parameters or setting it up.
I can't help if you haven't got the Docs because it's not something that can be guessed at.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Connect spindle to mach
By Duffman in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 14-07-2020, 06:08 AM -
Spindle won't run using mach 3
By ryanjgreen in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 20-10-2019, 06:44 PM -
Spindle not spinning and got warm to touch
By Palletlad in forum General ElectronicsReplies: 3Last Post: 29-06-2019, 06:47 PM -
CNC 3040T-DJ Router spindle won't stop spinning
By Chilli in forum Chinese MachinesReplies: 5Last Post: 19-11-2016, 01:33 AM -
Problem with Spindle not spinning
By Noplace in forum Spindles & Drive MotorsReplies: 4Last Post: 22-01-2016, 02:40 PM
