    Hi Bernard, the spindle is a 220v 3 phase spindle and the board is a very basic VFD which converts 220v single phase to 220v 3 phase and allows speed control.
    I was under the impression that it worked in manual mode but you wanted to control it using mach3. This changes things slightly because obviously if it doesn't work in manual mode it suggests some thing is wrong and therefore won't work under mach3 control even if it was possible.
    So first we need to get it working in manual mode, however this could be easier said than done because it's most likely a parameter setting and without the manual then we are just guessing in the dark. If you have the manual then Zip it up and post or give us a link to it if online.
    It could be the switch or a wrong connection so please take pictures of the terminals on the control board so we can see what wires are used. This will also confirm if Mach3 can control it.!
    Also take pictures of the other 2 boards but concentrate on wiring and terminals. Try to take the pics so they show the terminals and where they lead, we don't need close up pictures just showing where they lead to and any markings on connectors etc.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Hi Jazz, here is the link to the 'User guide for CNC 3040. Hope this will help. I followed this guide.
    https://www.china-cncrouter.com//dow...7282452561.pdf
    Quote Originally Posted by Bernard View Post
    Why would you use that when it's clearly a completely different control box to what you have.? Just because it's called 3040 doesn't mean they are all the same.!
    You need the relevant docs to the control box you have. In any case that type of document wouldn't be any use for checking the VFD parameters or setting it up.
    I can't help if you haven't got the Docs because it's not something that can be guessed at.!
  1. Connect spindle to mach
    By Duffman in forum Gantry/Router Machines & Building
    Last Post: 14-07-2020, 06:08 AM
  2. Spindle won't run using mach 3
    By ryanjgreen in forum Artsoft Mach (3 & 4)
    Last Post: 20-10-2019, 06:44 PM
  3. Spindle not spinning and got warm to touch
    By Palletlad in forum General Electronics
    Last Post: 29-06-2019, 06:47 PM
  4. CNC 3040T-DJ Router spindle won't stop spinning
    By Chilli in forum Chinese Machines
    Last Post: 19-11-2016, 01:33 AM
  5. Problem with Spindle not spinning
    By Noplace in forum Spindles & Drive Motors
    Last Post: 22-01-2016, 02:40 PM
