    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 4 Weeks Ago Has been a member for 7-8 years. Has a total post count of 985. Received thanks 118 times, giving thanks to others 52 times.
    If it's only capacitors that have failed they are cheap and easy to replace. Aluminium capacitors are a common point of failure for many power supplies. If the ends (larger capacitors usually have a cross indented on them) are even slightly bowed then this is a sure sign of failure. The worlds landfill sites are full of billions of dollars worth of failed electronics that could have been repaired by replacing a 50c aluminium capacitor with that tell-tale sign.
    Hi again Kit,
    Oh yes, the capacitors are BLOWN! And i really mean that with the capitals! one is fully exploded and all the others are a horrible shape! Due to the single phase problem I think it may be easier to just go with the vfd for the main drive and salvage the old parts for later use/repair/sale.
    I have a fairly large stock (read as hoard) of older electronic devices that i have "saved" from the tip. Much to the dismay of my everloving girlfriend! Waste not, want not!
    Thanks for the suggestion,
    Mort
  1. NEW MEMBER: cncest help getting started
    By johnnyrey in forum New Member Introductions
    Last Post: 02-07-2018, 07:40 AM
  2. Getting started and already confused
    By Palletlad in forum General Computing
    Last Post: 12-01-2018, 11:00 PM
  3. NEW MEMBER: New to CAD, looking for help in getting started cutting CF sheet
    By Devil_WAH in forum New Member Introductions
    Last Post: 23-02-2017, 07:30 PM
  4. Getting started BobCAD V27
    By peter gillespie in forum BobCAD-CAM
    Last Post: 11-06-2015, 12:00 PM
  5. NEW MEMBER: Started building!
    By bobgrant in forum New Member Introductions
    Last Post: 02-09-2010, 09:42 AM
