06-12-2020 #21
Okay, I wasn't clear - I was really talking about resistance, not voltage, with the machine powered off and across the limit switch, disconnected from the controller.
But, perhaps this is a good time to stand back and ask what you're trying to do? That isn't intended as anything other than perhaps an opportunity to provide perhaps a better solution to where you're heading.
Limit switches are useful to stop a large machine destroying itself, however, please understand that by the time you've hit a hard limit you're pretty much failed in planning your work. Most people will use "soft limits" - where the control software can recognise that it's going to hit an axis limit. A quick google suggests that grblcontrol recognises soft limits.
What soft limits does require, is resolving a known machine coordinate - and this is where your existing 3 axis inputs work as "home" switches, not "limit" switches. That would allow you to power the machine, select "home" for each/all axis, after which the machine will move each axis until each switch is active - at that point the machine knows where the spindle is, and you then configure the X/Y/Z constraints from that as "soft" limits (i.e. software-based offsets from the machine home position). You don't then need the additional switches, and you have more control over managing the machine (as the controller knows exactly where the spindle is at all times).
Suggest you read up on soft limits, homing switches, machine and work coordinate systems. I do believe that if well supported, that a homing/soft-limit set-up will give you a better experience than just hard limit switches. Going down that road will require that you disable machine limits (from what I've briefly seen of grbl, $21), and enable Homing, and that should resolve your latter question.
Note, although there are a few owners on here with GRBL-based controllers most of us are using somewhat different motion controllers/software - you might find better support for GRBL queries within a GRBL user group.
06-12-2020 #22
Doddy
Thanks for the input.
Up to now I have been using offsets to position the spindle home adjacent to where I want to start cutting. I then unplug and reconnect the USB cable to reset the machine co-ordinates to that position. That way I can clamp the stock where I like. For the few jobs I have done so far this has worked, but it includes a lot of jogging with the corresponding risk of running out of space. Hence my desire for limit switches to stop hitting the buffers when jogging.
I have read about setting up a fixed "home" position and including line of Gcode in a standard "footer" to make the spindle to return to that home position at the end of every job, so it becomes the machine coordinate origin every time the machine is reconnected, but felt that at this stage of my learning to speak CNC there was enough to be getting on with.
I kind of get the concepts behind setting up a home at one end of the axes and using soft limits for the other ends, so I will spend some more time as you suggest and see if I can use just 3 switches - which I have enough connectors on the board to accommodate.
Thanks again for your help.
06-12-2020 #23-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
06-12-2020 #24
Thanks JazzCNC
I think I've got some more reading to do!
Good luck.
How accurate is a Chinese 3018?
By RogerH58 in forum Chinese MachinesReplies: 0Last Post: 27-05-2020, 04:34 PM -
mach3 wont reset keeps saying external emg stop requested
By Geoff57 in forum Boxford LathesReplies: 49Last Post: 02-04-2020, 05:51 PM -
Probs installing UC300ETH on XP
By stirling in forum CNCdrive (UCCNC)Replies: 4Last Post: 21-07-2018, 10:04 AM -
Installing Mach 3 is driving me mad!
By tonygagey in forum Artsoft Mach (3 & 4)Replies: 16Last Post: 13-07-2015, 01:20 PM -
Cutting bits nomenclature - help requested
By DanielF in forum Tool & Tooling TechnologyReplies: 2Last Post: 12-05-2012, 04:53 PM
