Page 3 of 6 FirstFirst 12345 ... LastLast
  1. #21
    I can see keys for Datum and Set Home.Obviously there is a distance in three axes from machine Home to Part Datum.Have you drawn the test shape at a point in space within Alphacam that would be outside the machine's limits?Maybe posting the Gcode would be illuminating.
  2. #22
    Quote Originally Posted by BEACHBLANKET View Post
    Apologies for the multiple posts!
    My findings are this:
    Job1: starts and stops after 1 second.
    Job2: limit exceeded in X 5016.500
    Job3: limit exceeded in X 5016.500
    All 3 jobs were based on material size of x1200, y600 z-15
    And a square cut x200,y200 to x400,y400 depth -5mm
    I'm bamboozled
    Sent from my Mi A1 using Tapatalk
    As routerdriver has stated. Can you please post up the GCode. We can have a look at what you are trying to run. If your able to copy and paste it into a post ill be able to run it on my machine for you and see if it works
    I am only at work till 10:15 this morning otherwise you may have to wait till Monday. Unless my partner goes into labour, in which case ill see you in two weeks
  3. #23
    Just had an idea. You using the standard post code for a 3 axis built within Alphacam? If this is the case this may be the problem. Send me private message with your email and ill send over the postcode free of charge and probably at the disgust of the firm I work for.
  4. #24
    START
    N1 (CLS,HOME)
    T1
    N2 M51
    "A"
    N3 !VX(0)=0
    N4 !VY(0)=0
    N5 (EPP,START,END)
    N6 M5
    N7 (CLS,HOME)
    N8 M30
    "START"
    N9 G27
    N10 G401H1
    N11 T.1 M6
    N12 M50
    N13 G0 X197.5 Y197.5 Z50 M3 S18000
    N14 Z10
    N15 G1 Z-5 F700
    N16 X200 Y400 F2800
    N17 X400
    N18 Y200
    N19 X197.5
    N20 G0 Z50
    N21 M5
    N22 M51
    N23 M71 M151
    "END"
  5. #25
    That's the Gcode file produced by Alphacam.
    I'm using the - Rye QMaxi Osai TC Multidrill - post processor.
    I did try the standard Alphacam 3axis one but that couldn't be received by the machine.
  6. #26
    Thanks again chaps....
    And fingers crossed all goes well for you and your partner in the baby department!!
  7. The Following User Says Thank You to BEACHBLANKET For This Useful Post:
  8. #27
    Just noticed....
    In line 13.... Go x197.5.....
    197.5x25.4 = 5016.5 (X axis error amount)
    I've been drawing in mm, I set the machine units to mm
    Unless machine defaults to inches after every power up?
  9. #28
    Operation List POST: qmaxAlan4
    OP 1 FINISH PASS TOOL 2 2 FLT TWIST FLUTE ALI (6.35MM)
    EFFECTIVE DIAMETER 6.35
    Feed Distance: 1341.1 Time for OP 1: 2m 34s
    Total Feed Distance ....................... 1341.1
    Tool Change Time .......................... 0m 10s
    Total Time ................................ 2m 44s
    Material: MDF
    Use Extraction
    START
    '(TEST)
    '(COMPONENT DATUM POSITION X = 25)
    '(COMPONENT DATUM POSITION Y = 55)
    N1 G71
    N2 M51 H1S-
    N3 M52D-
    N4 M51 H2S-
    N5 M5
    N6 M51 H3S-
    N7 M5
    N8 M51 H4S-
    N9 M53D-
    '(OP 1 FINISH PASS TOOL 2 2 FLT TWIST FLUTE ALI (6.35MM))
    '(EFFECTIVE DIAMETER 6.35)
    N10 M06 T2
    N11 G0 Z70
    N12 M51 H2S+ 'HEAD 2 DOWN
    N13 G0 Z70
    N14 M3 S55
    N15 G0 X238.51 Y340.22
    N16 G1 X238.51 Y340.22 Z15 FX4
    N17 G1 X581.11 Y340.22 FX3
    N18 G3 X584.28 Y343.39 CX581.11 CY343.39
    N19 G1 X584.28 Y633.85
    N20 G3 X581.11 Y637.03 CX581.11 CY633.85
    N21 G1 X238.51 Y637.03
    N22 G3 X235.34 Y633.85 CX238.51 CY633.85
    N23 G1 X235.34 Y343.39
    N24 G3 X238.51 Y340.22 CX238.51 CY343.39
    N25 G0 Z70
    N26 M5 'HEAD 2 STOP
    N27 M51 H2S- 'HEAD 2 UP
    N28 M2
    try that, just bare in mind I have my offset x25 y55 it shouldn't make any difference to you though.
    This will just run a travel safe 70 from the 0 and it thinks you have a 18mm sheet on the bed and it will cut 13mm from 0 in a square.
  10. The Following User Says Thank You to finski84 For This Useful Post:
  11. #29
    As im currently finishing a job I wont get the chance to test your code but I have emailed my self the post code if you decide you want to try it when im at home
  12. #30
    Ive imported your code into my test file and you can see what your code was trying to do at least.
    Side view of your orange tool line.
  13. The Following User Says Thank You to finski84 For This Useful Post:
  1. NEW MEMBER: NEWBIE(ISH) with a RYE Quantum QM2515
    By BEACHBLANKET in forum New Member Introductions
    Last Post: 18-07-2020, 01:22 AM
  2. BUILD LOG: belt drive to ballscrew drive changeover advice required
    By marbles in forum DIY Router Build Logs
    Last Post: 14-02-2020, 02:14 AM
  3. Drive pulley size, Y drive redesign
    By threedee in forum Belt Drive, Pulleys & Timing
    Last Post: 01-08-2019, 10:56 PM
  4. Bridgeport Romi EZ Path S - Axis Drive Fault
    By Nemo1966 in forum Machine Discussion
    Last Post: 12-02-2018, 01:13 PM
  5. fixed one fault, not i have a second
    By terry1956 in forum CAD & CAM Software
    Last Post: 17-02-2016, 08:34 PM
