    Quote Originally Posted by BEACHBLANKET View Post
    Thanks again for your input.
    I'll check and clean all the switches...
    (It was the cabinet switch that threw up the original drive fault)
    I know it's a big ask... would you be able to jot down what you do from power on to loading a job?
    Ie.
    1...press home
    2...press datum etc...
    It would be an enormous help for a CNC virgin!!
    My manuals also consist of the machine schematics... I've literally searched for 2 days solid for something on the Omicron 3000, all I found was a brochure.... I'll post it up later.
    Many thanks Derek
    Sent from my Mi A1 using Tapatalk
    First I just want to say sorry for the state of the pictures. Just quicker for me to take a picture of my old notes as I'm currently at work
    Second I want to state that my usable working area on the bed is offset by x55 y25 which you will see in the first picture (ignore the scratch bed I'm about to change it )
    (ignore the head 3 and head 4 swap, we had a electrical issue and the cable didn't reach anymore so they kept it cheap and swapped the cables)
    As you see in this one you will notice my notes regarding the offset I have setup. I assume you woul just insert zero in both of these.
    Then its just a matter of sending the program and hitting start
  2. The Following User Says Thank You to finski84 For This Useful Post:
  1. NEW MEMBER: NEWBIE(ISH) with a RYE Quantum QM2515
    By BEACHBLANKET in forum New Member Introductions
    Last Post: 18-07-2020, 01:22 AM
  2. BUILD LOG: belt drive to ballscrew drive changeover advice required
    By marbles in forum DIY Router Build Logs
    Last Post: 14-02-2020, 02:14 AM
  3. Drive pulley size, Y drive redesign
    By threedee in forum Belt Drive, Pulleys & Timing
    Last Post: 01-08-2019, 10:56 PM
  4. Bridgeport Romi EZ Path S - Axis Drive Fault
    By Nemo1966 in forum Machine Discussion
    Last Post: 12-02-2018, 01:13 PM
  5. fixed one fault, not i have a second
    By terry1956 in forum CAD & CAM Software
    Last Post: 17-02-2016, 08:34 PM
