24-07-2020 #15
Operation List POST: qmaxAlan4
OP 1 FINISH PASS TOOL 2 2 FLT TWIST FLUTE ALI (6.35MM)
EFFECTIVE DIAMETER 6.35
Feed Distance: 1341.1 Time for OP 1: 2m 34s
Total Feed Distance ....................... 1341.1
Tool Change Time .......................... 0m 10s
Total Time ................................ 2m 44s
Material: MDF
Use Extraction
START
'(TEST)
'(COMPONENT DATUM POSITION X = 25)
'(COMPONENT DATUM POSITION Y = 55)
N1 G71
N2 M51 H1S-
N3 M52D-
N4 M51 H2S-
N5 M5
N6 M51 H3S-
N7 M5
N8 M51 H4S-
N9 M53D-
'(OP 1 FINISH PASS TOOL 2 2 FLT TWIST FLUTE ALI (6.35MM))
'(EFFECTIVE DIAMETER 6.35)
N10 M06 T2
N11 G0 Z70
N12 M51 H2S+ 'HEAD 2 DOWN
N13 G0 Z70
N14 M3 S55
N15 G0 X238.51 Y340.22
N16 G1 X238.51 Y340.22 Z15 FX4
N17 G1 X581.11 Y340.22 FX3
N18 G3 X584.28 Y343.39 CX581.11 CY343.39
N19 G1 X584.28 Y633.85
N20 G3 X581.11 Y637.03 CX581.11 CY633.85
N21 G1 X238.51 Y637.03
N22 G3 X235.34 Y633.85 CX238.51 CY633.85
N23 G1 X235.34 Y343.39
N24 G3 X238.51 Y340.22 CX238.51 CY343.39
N25 G0 Z70
N26 M5 'HEAD 2 STOP
N27 M51 H2S- 'HEAD 2 UP
N28 M2
try that, just bare in mind I have my offset x25 y55 it shouldn't make any difference to you though.
This will just run a travel safe 70 from the 0 and it thinks you have a 18mm sheet on the bed and it will cut 13mm from 0 in a square.
The Following User Says Thank You to finski84 For This Useful Post:
NEW MEMBER: NEWBIE(ISH) with a RYE Quantum QM2515
By BEACHBLANKET in forum New Member IntroductionsReplies: 8Last Post: 18-07-2020, 01:22 AM -
BUILD LOG: belt drive to ballscrew drive changeover advice required
By marbles in forum DIY Router Build LogsReplies: 4Last Post: 14-02-2020, 02:14 AM -
Drive pulley size, Y drive redesign
By threedee in forum Belt Drive, Pulleys & TimingReplies: 7Last Post: 01-08-2019, 10:56 PM -
Bridgeport Romi EZ Path S - Axis Drive Fault
By Nemo1966 in forum Machine DiscussionReplies: 0Last Post: 12-02-2018, 01:13 PM -
fixed one fault, not i have a second
By terry1956 in forum CAD & CAM SoftwareReplies: 0Last Post: 17-02-2016, 08:34 PM
