01-08-2020 #2
To vastly over simplify,It will run all sorts of machines once you have explained to it how many steps/unit of travel.For my hobby machine,on steppers,it was mostly a case of finding out how quickly the computer that runs the machine could churn out pulses,estimating an acceleration rate and determining the number of steps per rotation of the ballscrew and thus from the pitch,the steps/mm.There is a forum abundantly populated by experts at https://forum.linuxcnc.org/.They will be better able to answer specific points.You can download it and run it live from a DVD or a memory stick before committing to an installation.
The Following User Says Thank You to routerdriver For This Useful Post:
NEW MEMBER: NEWBIE(ISH) with a RYE Quantum QM2515
By BEACHBLANKET in forum New Member IntroductionsReplies: 8Last Post: 18-07-2020, 01:22 AM -
BUILD LOG: belt drive to ballscrew drive changeover advice required
By marbles in forum DIY Router Build LogsReplies: 4Last Post: 14-02-2020, 02:14 AM -
Drive pulley size, Y drive redesign
By threedee in forum Belt Drive, Pulleys & TimingReplies: 7Last Post: 01-08-2019, 10:56 PM -
Bridgeport Romi EZ Path S - Axis Drive Fault
By Nemo1966 in forum Machine DiscussionReplies: 0Last Post: 12-02-2018, 01:13 PM -
fixed one fault, not i have a second
By terry1956 in forum CAD & CAM SoftwareReplies: 0Last Post: 17-02-2016, 08:34 PM
