Page 4 of 5 FirstFirst ... 2345 LastLast
  1. #31
    Hi John
    Before you get a new graphics card you are going to have to check if your computer takes a half height or a full height card.
    Andrew
    Ps Maybe going to windows 10 or backwards to windows 7 (now obsolete but much easier to work with (at least for an old fart like me)) might solve your driver problem !
  2. #32
    Hi again to all!
    I was actually wondering that and actually wondered if I should go back to 32 bit. This machine is 32 bit and seems to have decent graghics (sufficient to handle UCCNC anyway)
    Am I correct that with 32bit I do not need a controller ? I seem to remember that Mach3 would self set up on certain functions with the simple parallel port connection.
    There are reasonable computers on Ebay for £80 or so .
    So what is best for this task ? It is primarily to run this CNC function
    32 0r 64 bit ?
    Win 10 or one of the older versions
    What do I look for if I want graphics which UCCNC will be happy with?
    It would be dead easy to spend a lot of money and still have troubles.
    Simple question is "what works best" ?
  3. #33
    Hi John
    If you haven't got a load of programs on the pc I would reinstall the operating system win 10 or 7 and see if the driver problem sorts itself out. I don't think for UCCNC it matters 32 or 64 bit . By the way did you get the registration on the uccnc forum sorted out.
    Andrew
  4. #34
    So a quick report!
    Have loaded a new Mach 3 profile which does not seem to help.
    I have checked connections and cant find errors , I have even run a new cable to y axis direct from driver to stepper and no improvement .
    Havent yet managed to install UCCNC but working on that.
    I am beginning to doubt the quality of kit I have , UC100 was obtained from a trusted source but could it have been spiked by other duff gear?
    I have had a couple of dubious Breakout boards , How do I know this one is OK?
    I have bought drivers from cheap sources as well as trusted sources but how do I know where even the trusted gear is being sourced ????
    I did have a failed motor , but all seem to run sweet now ,
    But all this kit seems to come from china so how on earth do I know what I am getting? and it is all so fragile anyway so if I get a failure then it is inevitably my own fault cos i must have shorted it ???
    Is it worth paying the extra for gecko say? Should I get new motors too and from where ??
    This seems to be a satisfying hobby but more than frustrating if things are going wrong.
    Rant over
  5. #35
    Quote Originally Posted by the great waldo View Post
    Hi John
    Andrew
    Got that sorted Andrew , Thanks for your help on that. . But still need to get the graphics sorted to see UCCNC working
  6. #36
    Right so!
    Heres the latest... I could still see that Y axis appeared to have a mind of its own . Sometimes would go , then it would stop.
    Wired the motor direct to the driver with no plug in the line -- No better.
    Found that Z axis would jog up , but not down. So changed the driver and that cured that problem.
    And lo I now find that Y axis is working fine too WTF
    Since then I have run two cam programs , the second quite a long one , with no fault. So why?????
    Why should changing the Z driver cure a problem with the Y motion.
    I am beginning to think that CNC is a black art which I have yet to master.
    I also wonder if I have got some cr@p drivers .
    Which drivers would you guys recommend ?
    Is it worth paying for Gecko?? Advice appreciated
  7. #37
    Lives in Plymouth, United Kingdom. Last Activity: 14 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,740. Received thanks 297 times, giving thanks to others 11 times.
    Quote Originally Posted by John11668 View Post
    Being honest Daz I dont really understand the ins and outs.
    I was advised by a chap I met at the Alexander palace model show( member of the society of experimental engineers and I understand he was their CNC guru) that in order to run Mach 3 on a 64 bit machine I needed a UC100 . It would not drive even a single stepper when I first tried .
    I took his advice and it then worked.
    Same gentleman guided me here so his advice seems sound enough.
    He may well be reading this thread !
    Probably me, although "guru" is putting it a bit strong. Sorry I can't help with UCCNC issues as I have never used it for real, just had a look at the demo version. I have had graphics card issues myself, although installing the latest graphics driver helped the last time this happened. Glad you found this site - great source of help and sounds as if someone is now guiding you.
  8. #38
    Hi Neale , and nice to hear from you again. Sorry if you feel that guru is too strong a term (I did not set out to cause embarrassment) but your colleagues on the stand on that day clearly felt you were their specialist , and therefore the man to advise me . I certainly appreciated your advice . Thanks again
    While UCCNC will be an interesting sideline for me, the urgency has abated due to the fact that Mach 3 seems to be working for me at the moment.
    I still do not fully understand why but I suspect that the quality of Kit was my main Issue, so am keen to explore that topic
    I can see that this thread has now run its course, so maybe i need to start a new one for advice on which kit will give me a robust control system .
  9. #39
    The first question to ask is it a genuine UC100 from CNCdrive motion controls or was it bought from eBay.?
    Next, I've seen this happen many times with various controllers, and often it's a corrupted Mach3 XML. Either create a new profile using the same settings or go into the XML backup folder and use an old one that you know worked. Personally I'd set up a new one.
    Or better still invest in UCCNC as it's now much better than Mach3.
    I took your advice on this Jazz and was quite happy with what I got until this week .
    I lost my licence as a result of a crash and having to reinstall Windows .
    UCCNC license disappeared too . I have asked them to resend email and two days later with much discussion on CNCdrive forum I am no further forward .
    As I said there it is like buying a new car and finding yourself calling for help from manufacturer then getting ignored .
    I am in no way trying to blame you jazz but just noting that while their software looks good their customer support can be second rate .
    This seems to be borne out by some reviews .
  10. #40
    If you go to your Email server you may still have the email if you didn't delete it.? . . . But this should serve as a lesson to back up to an external source ie: USB stick or offsite drive like Dropbox.!!
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. Erratic stepper motors
    By martin54 in forum Motor Drivers & Controllers
    Last Post: 30-06-2020, 11:58 PM
  2. CNC 5 axis Setting/ Operating/ programming??
    By 5axismilling in forum General Discussion
    Last Post: 01-09-2018, 04:17 PM
  3. FOR SALE: FOR SALE 2 x Denfords with 1 operating PC
    Last Post: 13-11-2015, 02:05 PM
  4. Random Erratic Possible Stalling Problem with router
    By Earle in forum Chinese Machines
    Last Post: 02-08-2015, 10:28 PM
  5. CNC3040 erratic stepper motor operation (fixed)
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 30-12-2012, 07:52 AM
