Thread: Which kit???
I really don't understand this question - if you mean is there a profile system (so you can load different configurations) then absolutely - create/save profiles and load them from a modified icon which provides the machines name. Details in the manual - and I use this to run two different mills perfectly well (even with a cheeky M9998 to provide relay switching between the motor drives on the two mills).
If you mean can you configure pins/ports etc, I'm sure you're there already if you've got it working - hence my confusion. The only annoying thing for me is the constant Apply/Save mantra to not lose settings - but from memory Mach was a bit like that - at least on the motor tuning pages.
27-07-2020 #2
28-07-2020 #3
