Thread: Which kit???
Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by John11668 View Post
    Right so BoB wont go amiss. Sounds like you are pessimistic about them Daz
    So am reporting back with some better news While I was jogging back and forth looking for a pattern I just happened to spot that when a jog failed , the red power light on he KK01 went out so on a failing jog the board power seemed to be dropping out.
    I rigged a power supply from a 5v PSU and moved the Jumper , and Hey presto , the problem seems to have gone away.
    Deep sighs of relief followed .
    I will still go though the wiring and upgrade the motor cables , also see that the screening is well grounded .
    Maybe get some work done now
    Thanks to all of you .
    Sounds promising. Can I suggest one thing - take a breath and consolidate your understanding of the problem and that is truly is fixed (I'm about 90% confident from your description), before making too many changes.
  2. #22
    Need to understand a few other things too in UCCNC before I will be confident with it , but really only been using it over the weekend . I think I will prefer it to mach3.
    One thing is when I change from Mach to UC (and Vice Versa) it "reinstalls the firmware for UC100 ?????
    I set the pin numbers for the homing switches on each axis and now it will home , but I never really understand why I can jog through these switch positions . If I hit them in a program it will stop .
    There is one helluva manual and It will take me some time to get to know the software . I will play for a day or two before I rehash the wiring.
    Is there a reconfigure function in UCCNC I havent found it if there is .
  3. #23
    I really don't understand this question - if you mean is there a profile system (so you can load different configurations) then absolutely - create/save profiles and load them from a modified icon which provides the machines name. Details in the manual - and I use this to run two different mills perfectly well (even with a cheeky M9998 to provide relay switching between the motor drives on the two mills).
    If you mean can you configure pins/ports etc, I'm sure you're there already if you've got it working - hence my confusion. The only annoying thing for me is the constant Apply/Save mantra to not lose settings - but from memory Mach was a bit like that - at least on the motor tuning pages.
  4. #24
    Have you got "Enable Soft Limits" turned of (Configuration - General Settings) if so that may be why you can jog through the home positions?
    You will also need to define the Soft Limits in the Axis Setup menu.
  5. #25
    Sorry Doddy
    Brain in neutral (It was late 0)
    I should have said "regenerate "
  6. #26
    Quote Originally Posted by ngwagwa View Post
    Just to report that changing the BoB to a PSU supply seems to have restored proper function so moving on:-
    I have enabled soft limits and set what I thought were sensible ones but things dont seem quite intuitive particularly on Y axis but I think a new thread is callled for
  7. #27
    Sorry Doddy
    So is there no Regenerate function in UCCNC
